ᐅ Installing a BILLY Bookcase Under a Sloped Ceiling – What Should Be Considered?
Created on: 5 Mar 2024 08:17
Dylanlo
I’m planning to install a Billy bookcase from IKEA under a sloped ceiling and I’m not entirely sure what to pay special attention to. The slope is quite steep, and I’m wondering how to best adjust the bookcase to make optimal use of the space while ensuring stability.
Are there any specific mounting methods I should consider during installation? What about cutting the back panels and sides? Is there anything I need to keep in mind regarding the materials since the bookcase will be installed directly against the slope?
I would appreciate any experiences, tips on precise measurements, and recommendations on how to securely fasten the bookcase without compromising stability or appearance.
Thanks in advance!
Thanks in advance!
Hi Dylanlo and all other shelf wizards!
Dealing with a sloped ceiling can sometimes be a bit of a challenge, but don’t worry, you’ll manage it 🙂
I would recommend always working with a tape measure and a spirit level, and be patient. As mentioned before, cutting to size on site is the best approach to get a perfect fit. For a visual check, you can at least assemble the shelf briefly to see how the shelves and sides behave.
Regarding securing the shelf: you can use small furniture glides on the floor to prevent wobbling. For the screws into the wall or slope, it’s better to use a few extra to ensure the unit is really stable. If the gap at the sloped ceiling bothers you, cover it with some decorative trim—this will make it look neat as well.
Good luck! The space under the roof is perfect to make the most out of a BILLY shelf 🙂
Wesley schrieb:
Regarding securing: You can also place small furniture glides on the floor underneath to prevent wobblingInteresting suggestion, but I wonder if furniture glides are more intended to facilitate movement rather than provide stability. Could they potentially even cause the shelf to slide?
My recommendation would be to equip the underside, if necessary, with non-slip rubber or felt pads that ensure a secure position without making the shelf movable.
Wesley also mentions decorative mouldings to hide gaps. That makes sense and adds aesthetic value, but it should not lead to ignoring uneven walls. If in doubt, it’s better to adapt the wall beforehand or compensate for irregularities.
