ᐅ Increase the stability of the BILLY shelf by using metal brackets.
Created on: 28 Jul 2022 08:12
Gobalu
some time ago, I bought a Billy bookcase from IKEA. Although the bookcase itself feels sturdy, I noticed that under heavier loads or when something hits it from the side, there is some play and it wobbles slightly. My question is:
How can I effectively increase the stability of my BILLY bookcase using metal brackets?
I am mainly thinking of simple but effective methods that don’t require complicated modifications or special tools. Are there proven positions for mounting the brackets? Should I attach them on the inside or outside? Which sizes and materials of brackets are best suited?
I am also interested in whether the brackets can simply be attached with wood screws or if other fastening methods are recommended. I want to make the bookcase as rigid as possible without compromising its appearance too much. Any tips or advice based on experience or theory would be greatly appreciated.
sarGabriel29 Jul 2022 08:45Brackets on the upper rear corners and screws into the wall – that’s all you need to do with BILLY to achieve greater stability. Simple, effective, and quick.
Gobalu schrieb:
Are there recommended positions for angle mounting? Should I place it more on the inside or outside? I recommend mounting on the inside at the back to preserve the appearance and ensure maximum stability. Mounting on the outside can look unattractive and doesn’t offer any real advantage.F
flo-Theres29 Jul 2022 10:50A tip for installation:
If you use metal brackets, choose ones with elongated holes. This provides some flexibility during mounting, making it easier to align the shelf and the wall precisely.
Additionally, this improves the distribution of forces, as the screws resist less under load. This can further increase stability.
flo-Theres schrieb:
use ones with elongated holes That is a good tip, as elongated holes also allow for some adjustment if the wall is not perfectly straight.
In summary: For optimal stability, brackets should be installed at the top and bottom rear corners, preferably on the inside, using suitable wood screws, elongated holes for alignment, and an additional wall fixing if possible.
