ᐅ Tall cabinet for built-in compact oven, compatible with Ikea Metod/Maximera systems
Created on: 21 Jan 2015 14:04
X
xscout77
X
xscout77
21 Jan 2015 14:04
I want to buy this Metod drawer cabinet and install a Siemens oven in it, which is only 45cm (18 inches) high.
I would like to fill the gap below the oven with a drawer and cut a 20cm (8 inches) high drawer front to fit.
Is this possible? How does the oven’s ventilation work in this case? Is it problematic to place a drawer directly below the oven?
Would HELANDE be a suitable option?
White tall kitchen cabinet with open center and two drawers
Good luck
IKEA-Experte
21 Jan 2015 15:06
it is basically just a slightly different version of this one:
Narrow white cabinet with open door, shelves, and four drawers at the bottom
X
xscout77
21 Jan 2015 15:39
Hello Ikea expert,
thanks for the tip.
Two things speak against this cabinet though:
1. I don’t want so many drawers at the bottom (at least not visible)
2. There is still a gap with this cabinet (I integrated it into my kitchen plan with a combination appliance 46cm (18 inches) high and there remains a gap).
IKEA-Experte
21 Jan 2015 16:15
Hello, you can of course choose the drawers almost freely. With the cabinet, I primarily wanted to show that drawers below the appliance are not a problem. If you look closely with a magnifying glass, you can also see an inserted strip above the top drawer. Actually, HELANDE should also be usable with the 45cm (18 inches) high appliance.
X
xscout77
21 Jan 2015 16:40
OK, then I'll see if I can combine the tall cabinet with a drawer and the Helande panel.
Z
zetterberg
22 Jan 2015 07:26
... Actually, HELANDE should also be usable with the 45 cm (18 inches) high unit.
Unfortunately not. Although the compact stoves have a nominal size of 45 cm (18 inches), the actual size is 45.5 cm (18 inches), so Helande no longer fits.
