ᐅ IKEA Metod: How can I build cabinets space-efficiently in limited areas?
Created on: 21 Mar 2020 09:43
Ludin
Ludin
21 Mar 2020 09:43
I am planning to install an IKEA Metod cabinet in my small kitchen but have very limited space available. My specific question is: How can I build IKEA Metod cabinets in the most space-efficient way possible without sacrificing storage capacity or making operation difficult? I am particularly interested in modular combinations, practical use of corners, and smart interior layouts, such as pull-outs or dividers.
Can anyone provide concrete tips on which dimensions work best, which cabinet types are preferred, or which additional accessories are useful to make the most of the available space? I want to avoid the cabinet being too wide or too deep, as the kitchen is small and clear pathways must be maintained.
Thanks in advance!
Israel62
21 Mar 2020 10:21
Metod standard heights (60 cm and 80 cm) as well as narrow widths (40 cm) are ideal for small kitchens.
- Corner cabinets with carousel or magic corners provide additional storage space.
- Narrow pull-outs inside the cabinet for better organization.
- Wall cabinets should not be too deep; 30 cm depth (12 inches) is usually sufficient.
LOJOPAR
22 Mar 2020 14:07
Here is a brief guide to help you systematically build your Metod cabinet in a space-saving way:
1. Create a floor plan and take precise room measurements – height, width, and depth of the planned installation space.
2. In small rooms, low cabinets (60cm high (24 inches)) with high-quality top units are often more practical than tall cabinets to keep the room feeling more open.
3. To avoid dead corners, I recommend corner base cabinets with a Magic Corner or a carousel unit.
4. Optimize the interior: narrow drawers for spices and small plates; taller drawers for pots. Widths of 20–40cm (8–16 inches) are sensible when space is limited.
5. Keep allowed depths in mind: base cabinets should be no deeper than 60cm (24 inches), while wall cabinets are better around 30cm (12 inches) deep to prevent the countertop from feeling cramped.
6. Make good use of height: plan adjustable shelves in the wall cabinets to store different items efficiently.
Summary: Plan with compact modules, use corner solutions, and focus on flexible interior fittings. This way, you can maximize storage and make the best use of limited space.
sarla
22 Mar 2020 18:34
Ludin schrieb:
How can I assemble IKEA Metod cabinets in the most space-saving way possible without sacrificing storage capacity or making them difficult to use? I’m especially interested in modular combinations, effective use of corners, and smart interior design, such as pull-outs or dividers.
Here are some recommendations:
- Use narrow cabinet widths (30–40 cm (12–16 inches)) to keep walkways clear.
- Corner solutions with Magic Corner or carousel units are effective because they utilize otherwise wasted space.
- Interior fittings with pull-outs improve accessibility, especially for deep cabinets.
- Modularity: work with multiple narrow units instead of fewer wide ones; this preserves maximum storage while allowing flexible arrangement.
Make sure the available space is not limited by overly deep base cabinets. Overall, adapt the cabinet dimensions to the room, make use of all corners, and plan the interior layouts thoughtfully.
raquel52
23 Mar 2020 08:19
Ludin schrieb:
Can anyone provide specific tips on which dimensions work best, which types of cabinets are preferred, or which additional accessories are useful to make the most of the available space?
Here are some additional practical tips on assembly and construction:
- Measure the clear width of the room precisely before installation, including any narrow spots, to choose the best cabinet size.
- Metod offers various units ranging from 20 to 80 cm (8 to 31 inches) wide. For small spaces, 40 cm (16 inches) modules are often a good choice.
- Corner cabinets should preferably be equipped with functional inserts (Magic Corner/carousel) to maximize storage capacity.
- Invest in internal pull-out systems, drawer slides, or drawer inserts to utilize cabinet depth and height efficiently.
Avoid unnecessary gaps inside the cabinet body that cannot be used. With careful planning, you can achieve a lot of storage space even with limited room using Metod.
