ᐅ Ikea Metod: How can I retrofit soft-close hinges on the doors?
Created on: 29 Sep 2015 08:43
DEOJURIAN
DEOJURIAN
29 Sep 2015 08:43
Hello everyone, I am planning to upgrade the doors of my Ikea Metod kitchen fronts with a soft-close feature. My question is: How can I convert the doors, which currently have standard hinges without damping, to soft-close without having to replace the hinges entirely? Are there compatible soft-close adapters that can simply be added onto the existing hinges? Or is it necessary to replace all hinges with special soft-close versions? Additionally, I am interested in whether the upgrade process differs for the various types of hinges in the Metod system (e.g., clip-on or cup hinges). I would appreciate any tips on installation, which specific parts are needed, and if there are common pitfalls to watch out for. Thanks in advance!
chenlen
29 Sep 2015 11:27
Retrofitting soft-close functionality on Ikea Metod doors is generally possible but usually requires replacing the existing hinges with soft-close models.
Ikea offers special soft-close cup hinges for Metod, available as both clip-on and drilled-in types. Simple retrofit using so-called soft-close adapters that clip onto existing hinges is not intended for Metod and rarely works technically because the damping mechanism is precisely integrated into the hinge body.
The procedure is as follows:
- Unscrew the old hinges
- Install the new soft-close hinges according to the existing drill holes
- Adjust the doors (soft-close hinges usually allow fine adjustment in three axes)
If you choose to use third-party soft-close adapters instead, they often do not fit Ikea hinge types optimally and can later cause damage or uneven closing. My advice: invest in the original Ikea soft-close hinges, as these are precisely matched and compliant with Ikea standards. For different hinge types (clip-on vs. drilled-in), there are indeed different replacement parts, so be sure to identify your existing hinge type accurately before purchasing.
If you need further details, such as which hinge numbers exactly fit your Metod model, I can gladly compile that information for you.
blaix
29 Sep 2015 14:16
chenlen schrieb:
Simple retrofitting using so-called soft-close adapters that clip onto existing hinges is not intended for Metod and hardly works technically
That sounds quite definitive, but I would like to question it a bit: Are there really no universal soft-close adapters that are not specifically designed for Metod hinges but could still be used? For example, there are small dampers on the market that can be glued or clipped directly onto the hinge arms. Are these completely ruled out, or have you had negative experiences with such products yourself?
Furthermore, in my opinion, before replacing all the hinges, it’s worth considering whether a more technical alternative such as magnetic dampers or slow-close rods might be an option. Especially if the old hinges are still in good condition, sometimes an innovative solution can help without having to replace everything entirely.
Ianlau
30 Sep 2015 09:04
I am happy to help explain this in more detail and make it easier to understand, even for beginners.
Ikea Metod kitchen cabinet doors typically use what are called cup hinges, which are installed in the cabinet carcasses. There are two main types: clip-on hinges, which simply snap onto the mounting plate, and screw-on hinges, which are fixed with screws. For the soft-close feature, the built-in damping inside the hinge mechanism is usually what matters most.
Because of this, retrofitting with external adapters does not work very well technically. These adapters often try to mechanically slow the movement without being perfectly matched to the opening dimension and hinge mechanism. The result is uneven closing motion or even increased wear and tear.
The best solution is to replace the existing hinges with original Ikea soft-close hinges. Installation is generally straightforward:
- Remove the door
- Unscrew the hinges
- Rehang and adjust the door
Depending on whether you have clip-on or screw-on hinges, you need the matching soft-close models. Ikea offers both types.
A tip: When removing the hinges, be careful not to damage the drill holes or the mounting plate, as these usually remain in place and are reused. Adjustment can be done afterward via screws to ensure the door closes properly and sits flush.
If anyone has more detailed questions about hinge types or alignment, I’m happy to assist.
keelko
1 Oct 2015 17:36
Ianlau schrieb:
The best option is to replace the existing hinges with original Ikea soft-close hinges.
I fully agree! That’s exactly what I did. And I can only say: once you get used to the soft-close feature, you never want to go back to those old slamming doors!
By the way, I chose the clip-on version because installation is super easy and quick.
One small tip: when hanging the doors, it’s best to do this with the hinges slightly open. This way, you can fine-tune the adjustment until they close perfectly.
For those who aren’t too strict about using original Ikea parts, it’s still very important to go for high-quality soft-close hinges. Otherwise, cheap replicas often cause more frustration than satisfaction in everyday use.
