ᐅ Ikea METOD: Easy and Safe Installation of Kitchen Cabinets, Suitable Even for Beginners
Created on: 24 Jul 2023 19:37
Flojordan
Flojordan
24 Jul 2023 19:37
Hello everyone, I am planning to assemble my first kitchen using the Ikea METOD system and have done some research on how the installation process works for absolute beginners. Since I have no background in DIY or construction, it is important for me to know whether assembling the METOD kitchen cabinets is really as easy and, above all, as safe as many descriptions and reviews suggest.
I am especially interested in whether there are practical tips for beginners to avoid common mistakes, and if there are recommended tools or special techniques that can significantly improve the assembly process. For example, are there particular steps where the installation becomes complicated due to the many individual parts? How about the stability in case some components are not assembled perfectly?
In short: Can anyone with experience or reliable knowledge confirm whether the METOD system is truly a safe and manageable solution for beginners? Are there perhaps tips on steps that should not be skipped to avoid frustration and rework? Thank you very much in advance for your feedback!
GOLO42
24 Jul 2023 20:14
Hello Flojordan,
Based on my experience, I can confirm that the Ikea METOD system is indeed manageable for beginners – but there are some important points to consider, without which the process can become more complicated or unsafe.
First of all: Ikea provides very comprehensive assembly parts and detailed instructions, which are generally well designed. However, you should be aware that the individual furniture pieces are often quite heavy, and precise work during assembly is essential – especially when it comes to correctly aligning the cabinets and securing the screws. Here are a few recommendations I find very useful:
- Preparation: Unpack and sort everything, separating parts and screws. Pay attention to the lists showing which parts are needed in what quantities.
- Tools: A good drill with a screwdriver attachment is advisable, as well as a tape measure (or ruler), spirit level, and a Phillips screwdriver.
- Step-by-step assembly: Assemble the cabinets separately before attaching them to the wall. This makes handling easier.
- Wall mounting: One of the essential safety points, especially for stability. Check carefully what type of wall you have (e.g., drywall, concrete, brick) and use the appropriate anchors.
- Accurate alignment: Use the spirit level at every step, otherwise misaligned furniture will cause problems with doors and drawers later.
- Care with fronts: The panels and doors require a certain level of delicacy, as they can be easily damaged if handled too roughly.
Flojordan schrieb:
Can anyone with experience or solid knowledge confirm if the METOD system really is a safe and easy-to-handle solution for beginners?
Yes, definitely – provided you take your time and proceed systematically. IKEA kitchens are designed for the DIY market, which is reflected in good instructions and standardized connections. Still, it is not a quick task you can finish in just one afternoon.
Flojordan schrieb:
Are there any tips on steps you definitely shouldn’t skip to avoid hassle and rework?
Don’t neglect the wall mounting – that’s the most important safety aspect. Also, be sure to install all shelves and back panels correctly; these also contribute significantly to stability.
If you like, I can put together a list of tools and common mistakes that often cause trouble. Also, do you plan to assemble the kitchen alone or will you have help?
emmett
25 Jul 2023 08:52
In short: Yes, METOD is suitable for beginners. It is important to follow the instructions carefully and to securely fasten the wall mounting. Tools such as a cordless screwdriver and a spirit level are essential. Mistakes during assembly often occur when aligning and fixing the components – take your time and proceed step by step.
PeoDaniel
25 Jul 2023 11:03
Hello Flojordan,
I completely agree with GOLO42 and emmett – METOD is really surprisingly beginner-friendly if you follow the instructions and work systematically. Having assembled my first kitchen myself some time ago, I can offer a few additional tips to help you feel more confident:
- Preparation is key: Sort everything out and make notes about which parts belong to which cabinet. This saves a lot of time and frustration.
- Allow enough time for each assembly step: Rushing leads to mistakes and frustration.
- Find a quiet, spacious workspace so that all parts are easily accessible and nothing gets lost.
- When assembling the cabinets: Start with the largest, load-bearing parts, then move on to the shelves and back panels.
- Wall mounting: This not only ensures safety but also prevents tipping under load, for example from open cabinet doors.
- If you have someone to assist, they can help with alignment – two sets of hands are better than one.
GOLO42 schrieb:
Definitely don’t neglect wall mounting, it’s the most important safety aspect.
I can only emphasize this. Beginners often underestimate the forces exerted on kitchen cabinets during use. Even small assembly mistakes can be well compensated for with proper wall mounting.
My motto when assembling METOD: Patience and careful work always pay off. If something doesn’t work out the first time, don’t get discouraged – as long as you follow the instructions, nothing should go permanently wrong.
Good luck with your project!
