ᐅ Protecting IKEA Malm Furniture in Everyday Use – What Are the Best Methods?
Created on: 4 Apr 2024 07:33
Renjan
I have several IKEA Malm furniture pieces—mainly dressers and nightstands—in my home, and I’ve noticed that they tend to get scratched and show signs of wear quite quickly in everyday use. The light-colored surface, in particular, is quite prone to small dents and marks, so I’m looking for the best ways and tips to protect this furniture for daily use.
I’m especially interested in practical solutions that offer more than just short-term protection, but truly help with long-lasting durability without significantly changing the appearance. Has anyone had experience with special protective films, coatings, or other methods that work well in everyday situations?
I’m looking forward to your tips and experiences!
lisku
4 Apr 2024 13:29
By the way, a tip: For heavily used surfaces, self-adhesive matte films from marine supplies can work quite well, as they are scratch-resistant and water-repellent.
Josefane
4 Apr 2024 16:23
I believe we should also critically consider whether protective films and coatings are truly the best solution. Sure, they prevent scratches – but what about breathability and the natural feel of the material?
GALENKU schrieb:
Transparent protective films or special furniture liners made of plastic work best.
Aren’t plastic films more likely to cause problems for the furniture surface in the long run? Condensation or trapped moisture can also lead to issues like swelling.
I think it would be better to invest in care with high-quality furniture waxes and combine that with mechanical protection by avoiding direct abrasion.
Franck
4 Apr 2024 18:02
I recommend a combination: clear protective films for high-traffic areas and regularly applying furniture oil or wax.
Josefane schrieb:
Aren’t plastic films more likely to damage the furniture surface in the long run?
That can happen with improper use, but if you change the film regularly and clean the surface in between, the issue is manageable.
Renjan
5 Apr 2024 08:18
Thank you all for your feedback! I will try regular cleaning before applying protective films and using wax.
Josefane schrieb:
I think it would be better to invest in care with high-quality furniture waxes and combine mechanical protection by avoiding direct abrasion.
Could you possibly recommend specific products? I would prefer to avoid aggressive cleaning agents that could damage the MDF surface.
Elias
5 Apr 2024 10:45
I can fully understand how frustrating it is when the furniture you’ve invested in quickly shows signs of wear.
What has helped me the most is mainly the combination of applying a light layer of wax and always handling the furniture carefully—so, for example, not sliding heavy objects back and forth on the dressers.
Renjan schrieb:
I prefer not to use aggressive cleaning products that could damage the MDF surface.
I have had positive experiences with beeswax-based products. They are gentle, protect the surface, and are environmentally friendly.
GALENKU
5 Apr 2024 11:24
If you want to be on the safe side: IKEA Malm surfaces also tolerate water-based furniture care products very well. These are usually mild and do not damage the finish.
