ᐅ How can I protect the surface of BILLY shelves during repair work?
Created on: 10 Dec 2022 08:07
eli40
Good morning everyone, I am currently planning some minor repair work on my IKEA Billy bookcases, mainly tasks like tightening screws, possibly small surface touch-ups, and realignment. I want to make sure the surface of the shelves isn’t damaged by tools, screwdrivers, or adhesives during these repairs. I am interested in which methods and materials you would recommend to best protect the surface of the Billy bookcases during this kind of maintenance. Are there proven protective measures, such as special films, covers, or similar aids that are easy to use and preserve the appearance? Thanks for your tips!
eli40 schrieb:
Are there any experiences on how it behaves when peeled off? Does the surface get damaged during removal or does adhesive residue remain?For high-quality protective films specifically designed for furniture, the adhesive layer is formulated to be removed without residue – provided you do not leave it on for several weeks or months. However, make sure to apply and remove the film at room temperature so that the adhesive does not bond too strongly.
eli40 schrieb:
I want to avoid leaving any lasting marks if possible.I would also suggest reconsidering whether full coverage with protective film is really necessary for the planned repair work. It is often easier to protect only the specific areas at risk with a soft cushion. Using protective film permanently seems to me like too much effort and carries the risk of damaging the surface underneath.
theota schrieb:
It is often easier to protect specific areas with a soft padding where damage could occur.That’s true, you’re right. I’m considering cutting a thin foam mat for the screwing work to specifically avoid pressure marks. Are there any recommendations on how to fix the mat in place so it doesn’t slip while screwing? Painter’s tape might work, as Hannah suggested, or would that hold too tightly?
rigau schrieb:
It’s best to start screws by hand to avoid damaging the surface.Good tip! I usually use a cordless drill, but tightening screws by hand before or after sounds reasonable. I will keep that in mind for the repairs. Thanks to everyone for the helpful advice on protecting the surface, especially the tips about felt, masking tape, and protective films. Very useful for my work plan!
