ᐅ IKEA Kallax – Maximum Load Capacity
Created on: 27 Apr 2016 12:05
IKEA-Experte
The one-kilogram (2.2 pounds) tolerance will probably still be acceptable, but I assume you want to use the microphone as well, which will make it even heavier. Kallax is made only of cardboard, hardboard ("back panel material"), and an outer frame of chipboard. At first, it will hold, maybe even for a long time, but possibly not forever.
I wouldn’t do it, especially if there is a risk that a child could be injured by it falling.
TobWen
28 Apr 2016 10:06
That may be true, but production and pricing are planned according to a specific purpose.
Therefore, I find it "strange" to get upset about that.
I’m only upset because Kallax is not an inexpensive product. As you can see, even a kitchen cabinet carcass is more stable.
What about Besta?
Unfortunately, I only have a maximum width of 76-77 cm (30-30.5 inches).
IKEA-Experte
28 Apr 2016 14:01
Unfortunately, I don’t have enough space for a circular saw.
What are the dimensions of the microwave?
IKEA-Profi
28 Apr 2016 14:38
[Quote]What about Besta?
Unfortunately, I only have a maximum width of 76-77 cm (30-30.3 inches).[/Quote]
Besta is available in a 60 cm (24 inch) width.
Or is that too narrow?
wolf2000
29 Apr 2016 08:57
I don’t really understand what this is about—what is the finished piece supposed to look like? Hanging on the wall? I also see that Kallax shelves support only 13 kg (29 lbs) per shelf.
If you want to cut Metod panels, you’re welcome to come over—I have the saw for that. But the holes for the connectors and so on would need to be redone as well...
I would build a “composite construction.” Cut a sturdy shelf board to size (have it cut), for example, from plywood. It can be thin (9 or 12 mm (0.35 or 0.47 inches)) and glued over the entire surface to the “microwave board.”
Best regards, Wolfgang
TobWen
4 May 2016 13:04
Footprint (width x depth): 30 x 40 cm (12 x 16 inches)
Besta is available in 60 cm width. Or is that too narrow?
That’s right, I saw Besta in the store. Do the KALLAX inserts fit in there?
I don’t really understand what this is about – what is the finished unit supposed to look like? Wall-mounted? I also found only 13 kg load capacity per shelf for Kallax.
The shelf is supposed to stand on the floor with the microwave on top. On some KALLAX page it says 20 kg maximum load as a wall cabinet.
If you want to cut METOD panels, you are welcome to come to me – I have the saw for that. But the holes for the connectors and so on would have to be redone as well…
Couldn’t you use brackets there and then additionally add a KALLAX-style cross brace for stabilization?
I would build a “composite construction.” Cut a sturdy shelf board to size – for example from plywood. It can be thin (9 or 12 mm) and be glued over the entire surface to the “microwave board.”
Did I mention I’m a geographer? I can handle a rock hammer, but nothing more.
IKEA-Experte
4 May 2016 13:10
If the thing is standing on the floor, then place a board underneath to prevent the legs from pressing through the surface, and you’re done.
