ᐅ Ikea Faktum tall cabinet – removing a drawer
Created on: 28 Jan 2010 20:25
axse74
axse74
28 Jan 2010 20:25
I’m new to the forum and have had an Ikea kitchen since 1992. To expand the kitchen, I recently bought a Faktum tall cabinet for the oven. Below the oven, there are two drawers included. Now my question: installing the drawers was very easy, just slide them in — done. Now I need to remove the drawers from the cabinet and thought it would be just as simple (according to the instructions: lift slightly and pull out). However, lifting them is proving to be more difficult than expected, so before I break something, I wanted to know if I just need to use more force or if there is a trick?
Regards
Maverick1854
28 Jan 2010 21:40
Take a look under the drawer. At the front of the running rail, there is a white plastic part (set inward). You need to push it in, for example with a screwdriver, then push the rail itself backward. That’s it...
If you have any questions, just ask...
Best regards, Maverick1854
axse74
28 Jan 2010 22:46
wow, thank you very much for the quick responses, I will try that first thing tomorrow.
I will report back whether it worked.
Regards
Maverick1854
29 Jan 2010 06:47
von Brootos am Do 28. Jan 2010, 22:38
@Brootos
Looks like someone was quicker 😉
Regards,
Maverick1854
axse74
29 Jan 2010 09:42
I just tried it out, and after a bit of searching, I found the "nipple" and it worked perfectly. It is quite fiddly, especially with the bottom drawer, as the space is understandably very limited.
Many thanks again for your quick help!
