ᐅ IKEA Besta DIY – How can I create integrated lighting?
Created on: 26 Dec 2021 18:32
Furuku
Hello everyone, I am planning to equip my IKEA Besta shelving unit with integrated lighting. I am aiming not only for an attractive look but also for a practical, durable, and as energy-efficient as possible solution. I would like to use LED strips and, if possible, install them so that they are hidden behind a cover or within recesses without losing the lighting effect. My questions: What type of LED strips do you recommend (warm white or cool white?), how do you manage power supply and wiring discreetly? Is there any experience with dimmers or remote controls for such a project? And what is the best way to mount everything without damaging the furniture structure? Looking forward to your tips and suggestions, thanks in advance!
tarju41
27 Dec 2021 13:17
If you are looking for doorbell chokes or dimmers, make sure they are suitable for DC 12 V. For Besta, indirect lighting in aluminum profiles is recommended, as it distributes the light better and protects the LEDs. For wiring: thin 2x0.14mm (0.0055 inch) cables are sufficient. A simple switch is usually enough, and remote controls are available as radio frequency or IR, which can be easily integrated.
SUBEN60
27 Dec 2021 16:40
It is important to design the system so that voltages and currents are compatible and the cable cross-sections can withstand the loads. LED strips usually operate on 12V direct current, which reduces the risk compared to 230V. Nevertheless, proper circuit protection is advisable. A PWM dimmer can be used for control, providing efficient and flicker-free dimming. The use of aluminum profiles not only improves heat dissipation but also ensures better visual light distribution. Wiring is best done with connectors to facilitate later maintenance or replacement.
Z
zartra
27 Dec 2021 19:05
KNUTGI schrieb:
A dimmer with remote control is the perfect finishing touch for me – this way I can adjust the atmosphere depending on the occasion, from bright reading light to a cozy TV evening.
I completely agree, especially if you use the lighting frequently, the flexibility is incredibly convenient. For best results, just stay flexible and opt for 12V – this usually makes installation easier and safer.
