ᐅ How can I modify the Ikea Besta modular system for changing uses?
Created on: 12 Dec 2022 08:12
CORNELIA63
Hello everyone, I purchased the Ikea Besta system for my living room to make it as flexible as possible for changing uses. Specifically, I want to modify the shelving unit so that I can use open shelves, closed cabinets, drawers, or a combination of these depending on my needs—possibly also including components for media storage or space for work materials. It is important to me that the modification is modular and doesn’t require major carpentry work, so I can easily change the configuration over time. Are there any practical tips, recommendations for additional components, or modifications you know of for a flexible conversion of the Besta system? Thanks in advance!
CORNELIA6315 Dec 2022 07:24Thank you all, you’ve already helped me a lot! One last question: Does anyone know of creative solutions with additional modular elements for customization, such as removable inserts, boxes, compartments, or even lighting, that work well with the Besta system? I want to make the system as multifunctional as possible.
Marlenepa15 Dec 2022 08:11An efficient trick is to use modular inserts made of plastic or fabric boxes that can be easily taken in and out. LED strips on the back panel also add a lot of flexibility and atmosphere. There are modular organizers available from third-party suppliers that can be easily installed in the compartments. This way, your Besta remains easily adjustable and multifunctional.
Marlenepa schrieb:
An efficient trick is to use modular inserts made of plastic or fabric boxes that can be easily slid in or out. I agree, these boxes are ideal because you don’t need any screwing when remodeling. You can also retrofit LED lighting using battery-powered options without much effort.C
CORNELIA6316 Dec 2022 07:50Perfect, that makes things much more interesting. I will start by experimenting with boxes and lighting, and then plan the fronts and shelves based on that. Thank you for your support!
