ᐅ What is the best way to install hanging rods in an Ikea PAX wardrobe?
Created on: 23 Jun 2023 08:24
RADEK
Hello everyone, I am currently planning a customized wardrobe solution using the Ikea Pax system and specifically want to optimize the installation of the hanging rails. My question is: What is the best way to install hanging rails in the Ikea Pax so that they are sturdy, have no play, and at the same time make clever use of space? Are there any proven installation tips or perhaps different options depending on the type of clothing (e.g., shirts vs. coats) that you would recommend? I am also interested in practical details such as screw types, mounting height, and distance to shelves. I would appreciate any experience and specific recommendations!
Gloriagl1024 Jun 2023 08:44The distance between the rod and the side wall should be sufficient to allow the hangers to hang freely without touching. Usually, 5-7 cm (2-3 inches) is enough, depending on the width of the hangers.
RADEK schrieb:
How do you measure the distance between the wardrobe rods and the side walls of the Pax during installation?Unfortunately, Ikea does not provide fixed guidelines here. The width of most clothes hangers ranges between 40 and 45 cm (16 and 18 inches). It is recommended to leave a distance of at least 6 cm (2.5 inches) from the center of the rod to the side wall, so hangers do not catch and can rotate easily.
I measure the hanger width and add some extra space as a buffer. You should also consider whether the rod will slightly bend under the weight of the clothes to compensate for possible space reduction.
Summary: - Minimum distance to the side wall: about 5–7 cm (2–3 inches) - Use the dimensions of the hangers to be used as a reference
