ᐅ How stable is the IKEA BRIMNES wardrobe after being assembled and disassembled multiple times?
Created on: 1 Jun 2023 08:27
budi59
I am considering purchasing the IKEA Brimnes wardrobe but have concerns about the stability of the piece after multiple assemblies and disassemblies. My specific question is: How stable and durable does the IKEA BRIMNES wardrobe remain with repeated assembling and disassembling? In particular, I am interested in whether such processes lead to structural weaknesses or increased wear on the joints (for example, due to the typical screw and dowel combination) and how the stability of the wardrobe can be assessed over longer periods.
It would be helpful to hear experiences with the furniture in exactly these situations or any reliable assessments. Thanks in advance!
JONSON
2 Jun 2023 12:15
The construction of the Brimnes wardrobe is based on a panel system made of particleboard with edge banding.
- It is important to understand that particleboard generally offers less reusability for screw connections compared to solid wood.
- Repeated assembly and disassembly inevitably cause micro-damage to the screw joints.
- This gradually affects stability, which is especially noticeable in the height of the wardrobe or on heavily loaded shelves.
Therefore, if frequent disassembly is expected, consider reinforcing individual joints (e.g., by adding metal brackets) or limit disassembly to only when necessary.
klo61
3 Jun 2023 08:02
In summary: For occasional moving or assembling once or twice, the BRIMNES is stable enough. However, if you regularly disassemble the wardrobe, you should either expect some wear or use aids to prevent damage.
- Tip: Before reassembling, rub the screw holes with a bit of wax to help the screws turn more easily without putting too much strain on the material.
- When in doubt, many users also recommend having spare dowels ready.
I personally have taken the wardrobe apart completely twice without any issues.
Curtis
3 Jun 2023 09:44
klo61 schrieb:
I personally disassembled the cabinet completely twice, and did not notice any problems.
This supports the assessment that occasional assembly and disassembly are unlikely to cause significant damage.
However, it should be noted that with somewhat weak materials and simple joints, each additional disassembly can increase the risk of reduced stability. Therefore, it remains a matter of care, the number of times the furniture is taken apart, and the measures taken to protect the material.
