ᐅ How stable are IKEA BRIMNES dressers when heavily loaded?
Created on: 7 Jan 2023 08:23
Komeus
I have a question specifically about the stability of the IKEA Brimnes dressers, especially when they are heavily loaded. I am interested in how much weight the individual drawers and the entire frame can handle when fully or nearly fully loaded.
I don’t just mean the usual storage of clothes, but also heavier items that can weigh several kilograms (pounds) per compartment. Are there any experiences or recommendations on how much weight the drawers can safely hold without compromising the structure?
I have read that the dressers are made of particleboard and MDF, and I am wondering if heavy use might cause warping or material fatigue.
What advice can you share from your experience? Will the dresser remain stable overall, or are there common weak points, especially under high loads?
Looking forward to your insights!
Kinbu
8 Jan 2023 08:34
I understand the concern regarding load-bearing capacity, especially when it comes to tools and heavier items. The Brimnes dresser is indeed not designed for very heavy loads.
However, the lifespan of the dresser can be extended by following a few basic guidelines:
- Avoid point loads and try to distribute weight as evenly as possible.
- Place the heaviest items at the bottom to prevent tipping and protect the frame.
- Make sure the drawer slides are properly and neatly installed to avoid unnecessary strain.
If the weight is still very high, I would recommend using furniture or workshop shelving specifically designed for heavy loads. Hopefully, this practical advice is helpful?
GLALEO
8 Jan 2023 10:02
Hey, I have been using a BRIMNES chest of drawers for about a year now, and I fill it quite heavily with tools and various materials. I can only say: as long as you don’t overdo it and don’t constantly take the heavy items in and out, it works great!
There is a slight creaking sound from the drawers, but nothing that is really bothersome. I am currently looking for ways to reinforce it a bit, maybe with metal brackets inside or something similar.
So: BRIMNES is surprisingly sturdy when used carefully. Definitely recommended for everyday use and moderate loads!
SETHBLA
8 Jan 2023 11:59
I agree with that. For everyday household use, the chest of drawers is solid.
However, if you regularly want to store over 10 kg (22 lbs) per drawer, you risk wear on the material and the runners. My advice: better to look for another solution for heavy loads.
