I have a question specifically about the stability of the IKEA Brimnes dressers, especially when they are heavily loaded. I am interested in how much weight the individual drawers and the entire frame can handle when fully or nearly fully loaded.
I don’t just mean the usual storage of clothes, but also heavier items that can weigh several kilograms (pounds) per compartment. Are there any experiences or recommendations on how much weight the drawers can safely hold without compromising the structure?
I have read that the dressers are made of particleboard and MDF, and I am wondering if heavy use might cause warping or material fatigue.
What advice can you share from your experience? Will the dresser remain stable overall, or are there common weak points, especially under high loads?
Looking forward to your insights!
I would like to provide a more detailed explanation of the internal technical aspects of the BRIMNES chest of drawers, in case that is helpful. The BRIMNES series is made from a combination of particleboard and MDF, as you already mentioned. This material is mid-range in price and sufficiently stable for normal household use, such as storing clothing or similar items.
- Load capacity: The shelves and drawers are fitted with basic metal runners that can support a maximum weight of about 10-15 kg (22-33 lbs). Exceeding this limit can impair smooth operation and may cause permanent warping.
- Frame and carcass: The carcass panels are relatively thin, which means lateral pressure or uneven weight distribution can affect their shape. It is therefore advisable to be cautious with heavy loads, especially in the upper sections.
- Recommendation: For heavy items significantly over 10 kg (22 lbs), I would recommend considering reinforced chests made with solid wood or metal frames. If you still wish to use the BRIMNES, it is best to distribute the load evenly across all compartments.
Could you specify what type of heavy items you intend to store? This would help refine the assessment further.
PLOMA schrieb:
Could you specify what kind of heavy items you plan to store? That would help to make a more accurate assessment.Good question! Specifically, I plan to store various tools and materials in the chest of drawers in addition to clothing, each weighing between 5 and 15 kg (11 and 33 lbs). These include small power tools, spare parts, metal pieces, as well as some bulky but heavy items like toolboxes or loose materials in boxes.
I’m concerned that the drawers might quickly reach their limits because the weight distribution won’t always be ideal—sometimes I have to store tools space-efficiently, even if that means one drawer may bear a heavier load in certain spots.
The BRIMNES dressers are not designed to support such heavy loads. The construction, made of particleboard and MDF combined with standard metal drawer slides, has a clearly defined load capacity of approximately 10 kg (22 lbs) per drawer. Higher point loads cause increased wear and can permanently damage the drawer slides and the frame.
Technically, the material’s density and bonding cannot withstand repeated heavy stress without deformation or breakage. Likewise, the connection between the back panels and the frame in IKEA furniture is often relatively thin, which further reduces stability under heavy weights near the top.
Recommendation: If high load capacity for uneven weights is necessary, professionally reinforced furniture or solid wood models with more robust slides should be preferred.
usbla schrieb:
The BRIMNES dressers are not designed to handle such loads technically.I agree with that, but I think many people generally overestimate the load capacity of IKEA furniture. Of course, it’s practical, attractive, and affordable, but “heavy-duty” is hardly a term that applies to these dressers.
Why would IKEA choose such inexpensive materials if they intended them for heavy loads? In my opinion, if you want to properly store something heavy, you shouldn’t rely on furniture like this. IKEA should be seen more as a stylish addition, not as workshop or heavy-duty equipment.
