ᐅ How long do Ikea Brimnes drawer slides typically last on average?
Created on: 27 Jun 2023 18:33
TEFLORA
TEFLORA
27 Jun 2023 18:33
Hello everyone, I am currently looking into the durability of furniture, specifically the Ikea Brimnes drawers. What I am particularly interested in is: How long do the drawer slides of this series typically last?
I am hoping to get a realistic assessment based on normal household use – so no extreme stress, but regular use over several years.
I am interested both in your personal experiences with these pieces of furniture over a longer period, as well as technical opinions on the quality and workmanship of the slide mechanisms. Are there any known weak points or common signs of wear? Or are the slides generally durable and sturdy?
It would also be great to know whether it is worth replacing the slides early to prevent problems, or if you can usually just wait calmly.
Thanks for your opinions and experiences!
klo61
27 Jun 2023 20:07
Hello and thank you for your detailed question, TEFLORA!
Regarding the Ikea Brimnes drawer slides, they generally last about 5 to 8 years under normal use without any issues. However, this depends heavily on how often and intensively the drawers are used and whether the load is distributed evenly. Many users report that after several years, the slides can become somewhat stiff, making it harder to open and close the drawers.
Typical weak points are usually the plastic mechanism or cracked metal parts under heavy load. Still, the durability is generally acceptable for the price; these are not high-end metal runners but rather budget-friendly versions suitable for regular household use.
If you plan to optimize usage in the long term, occasional inspection and lubrication of the slides can help extend their lifespan. I would only recommend replacing them prematurely if problems already occur, as changing the slides is usually quite a bit of work.
If you want more detailed information or advice on replacement, feel free to ask!
JORGERON
28 Jun 2023 07:41
On average, the Brimnes drawer slides last about 6 years with normal use. After that, wear usually becomes noticeable, and the drawers may become harder to close. Regular maintenance can help extend their lifespan somewhat.
Surela
28 Jun 2023 15:27
Hello TEFLORA,
I would like to take the opportunity to provide a more detailed analysis of the durability of the Ikea Brimnes drawer slides. Ikea’s drawer slide systems, especially in the Brimnes series, mostly use a simple ball-bearing slide design with some plastic components for smooth movement and positioning. This means, from a mechanical standpoint, they are not designed for heavy-duty use but rather for everyday, normal use.
From a technical perspective, several factors are crucial in affecting the service life:
- Material quality: The slides are made of steel with a certain level of zinc coating, which protects against corrosion but is not fully durable under conditions of moisture exposure.
- Mechanics: Ball bearings and plastic guides experience wear due to friction. Over time, lubrication decreases, leading to increased friction and stiffer operation.
- Installation: Improper installation can cause uneven load distribution, resulting in premature wear.
Under normal conditions—meaning daily use with moderate load (weight of the drawer and contents around 10-15 kg (22-33 lbs)) and a clean environment—experience shows a usable life of approximately 5 to 7 years. With heavier use, this can reduce to 3-4 years.
Also important: Maintenance such as cleaning the guide rails and re-lubrication with a suitable lubricant (e.g., silicone oil or specialized mechanical grease) can usually extend the service life by 1-2 years.
It would be interesting to know how you are using your drawers specifically. In particular, how heavily they are loaded and how often they are opened.
Have you noticed any signs of stiffness or similar issues, TEFLORA? It does make a difference whether the slides are already noisy or if everything is still running smoothly.
TEFLORA
29 Jun 2023 10:18
JORGERON schrieb:
On average, the Brimnes drawer slides last about 6 years under normal use.
Thank you, that’s a pretty clear figure to use as a reference.
Surela schrieb:
Under normal conditions, meaning daily use with moderate load (the drawer and contents weighing around 10–15 kg (22–33 lbs)), and a clean environment, we typically see a service life of about 5 to 7 years.
Surela’s information matches my situation quite closely. The load is indeed moderate, and the drawers are used daily, though not continuously.
Currently, I’ve noticed that one of the drawers feels a bit stiff when closing, but there have been no other issues so far. I haven’t tried lubricating it yet, so I can still give that a try.
I’m also curious: are there replacement parts available from IKEA for the Brimnes drawer slides that can be ordered individually? Or is it common to replace the entire sliding mechanism if it breaks?
Thanks for the great discussion so far!
klo61
30 Jun 2023 09:52
TEFLORA schrieb:
Are there replacement parts available from Ikea for the Brimnes drawer slides that can be ordered individually?
Ikea offers spare parts for many of their product lines, but availability of individual drawer slide components for Brimnes is not always guaranteed. Usually, you can get complete sets of slides or full drawer units, but not small parts like ball bearings on their own.
If you only need to replace the slides, it can sometimes be easier to buy complete drawer slides from third-party suppliers—they are often more durable and less expensive than original Ikea parts. Just make sure the dimensions fit.
For lubrication, I recommend a thin silicone spray or a special lubricant designed for metal slides. Regular maintenance can significantly slow down wear and tear.
If you want, I can provide a step-by-step guide on how to replace or maintain the slides.
