ᐅ What is the best way to transport BILLY shelves without causing any damage?
Created on: 23 Jul 2024 08:37
BettinausB
Bettinaus23 Jul 2024 08:37Hello everyone,
I recently bought BILLY shelves from IKEA and am now facing the challenge of transporting them without damage. My question is: What is the best way to transport BILLY shelves to avoid scratches, dents, or other damage? Which types of packaging, padding, or transport methods are recommended to safely move the shelves from point A to point B, whether by car, van, or shipping service? I would really appreciate any tips and experiences, as the shelves have relatively thin side panels and I’m worried they might get damaged during transport. Thank you in advance!
Hi Bettinaus,
“You’re right that the shelves have relatively thin side panels” – that really makes transporting them tricky. I would recommend transporting the shelves lying flat whenever possible, definitely avoid standing them upright! A simple but very effective method is to wrap them in blankets or thick woolen covers. This will help prevent scratches and small dents.
It also really helps to place cardboard sheets between each shelf to avoid direct contact that could cause abrasion. When placing them lying flat in the car, it’s best to secure them with some cushions or foam padding along the edges to keep them from sliding around.
Oh, and very important: always be careful when loading and unloading – the corners can easily become a tripping hazard 😉 Good luck, and please let us know how you end up transporting them!
Hello Bettinaus,
To answer your question thoroughly, it’s important to consider several factors: size, weight, material, and especially the type of surface during transport.
First of all: BILLY shelves, although relatively light, have delicate, thin particleboard side panels. Normally, they are transported flat to avoid twisting. Ideally, the shelves should be laid down on a smooth but non-slip surface — for example, on a folded blanket, as juMira46 already suggested.
A crucial point is padding the corners and edges. These should be protected with foam corner protectors or sturdy cardboard edges. If professional materials aren’t available, folded cardboard pieces secured with fabric tape are also suitable.
Additionally, securing the load inside the vehicle is very important. Especially when using a van, straps should be fastened to stable anchor points. This prevents the shelves from shifting during braking or turns and rubbing or hitting against impact surfaces.
One more tip: if you disassemble the shelves (for example, removing the back panel), they can be stacked more compactly and securely.
I would be interested to know the exact transport conditions — car, van, or freight service? Any aids available? Then I can give more specific advice.
Bettinaus24 Jul 2024 07:28Domau0 schrieb:
I’m curious about your transport conditions – car, van, or freight company?Thanks for the detailed answer! I will transport the shelves lying flat in my station wagon. It’s not a van, so there isn’t a lot of space, but I can fold down the back seats. The shelves are still in the original packaging, although I feel the packaging doesn’t provide much cushioning. I have extra blankets and thick towels available.
Maybe also important: the distance is about 30 meters (19 miles), so not very long, but there are some potholes on the road.
I’m currently considering whether to wrap the shelves individually in blankets, placing something between them as you recommended, or whether it’s better to keep the packaging on and just add extra protection on the corners. What’s your opinion on this?
Hello Bettinaus and all interested parties,
Regarding the transport of BILLY shelves in their original packaging: While the packaging protects the parts from major damage, it is not designed as cushioning. Especially when the items are moved during transport, the original box usually isn’t enough to reliably prevent scratches and dents.
My detailed advice:
1. Wrapping: Since you have blankets, wrap each shelf piece individually, even if they are still in the box. This provides extra padding and absorbs shocks.
2. Layering: Place cardboard or foam sheets between the pieces to prevent them from rubbing directly against each other.
3. Edge protection: The corners of BILLY shelves are particularly vulnerable to impacts. Thick padding like foam corner protectors or improvised folded cardboard pieces secured with tape can be very helpful here.
4. Careful loading: When loading and storing in the vehicle, make sure the shelves cannot shift. Securing them with ratchet straps or tie-down straps is best.
5. Driving style: Since you mentioned potholes, drive carefully to avoid unnecessary jolts.
One last question: Are you planning to transport the shelves fully assembled or disassembled? Disassembled, they are easier to handle, but reassembling takes time and care—especially to avoid damage when handling the back panels.
I hope these tips help you!
My detailed advice:
