I recently bought a Billy bookshelf from IKEA and, after some time, noticed that it is prone to scratches in many areas, even though I handle it very carefully. My question is: why are some Billy bookshelves more susceptible to scratches than others? Are there differences in material quality, manufacturing, or external factors that affect this vulnerability? If so, how can these differences be explained in detail? Additionally, I would like to know if there are any tips to protect the shelf from scratches better without needing to treat it completely differently.
It is worth paying attention to the quality of workmanship and production batches. Some Müller or IKEA stores have shelves from slightly different production phases. In forums, people mention that the finishing of the veneer has improved over time. Older or earlier-produced shelves often had thinner veneers that are more prone to damage. A practical tip is to check for visible defects when purchasing and to address them with the seller if necessary. Additionally, keep in mind that light-colored surfaces typically show scratches more clearly than darker finishes.
Regarding material quality, I can say from experience that a smooth melamine finish is standard for Billy shelves, but there are versions with an additional protective layer that are somewhat more scratch-resistant. Unfortunately, these shelves are usually more expensive. Although the basic construction is the same, the surface treatment makes the biggest difference. Additionally, shelves that have been stored for a long time or poorly packaged are often more prone to small chips or cracks, which then appear as scratches. Another tip is to avoid placing books or objects directly on the surface; instead, use protective pads such as felt glides to prevent scratches.
Here is a brief "mini-tutorial" on the topic of scratches on Billy shelves:
1. Material: The shelves are made of particleboard, coated with melamine or lacquer finishes.
2. Coatings: Melamine foil is thin and less durable; lacquer offers more protection.
3. Manufacturing quality: Production batches affect the material thickness and surface quality.
4. Surface type: Matte and light-colored surfaces show scratches more quickly than smooth or dark ones.
5. Handling: Protecting against mechanical stress is important, e.g., using felt pads under items.
6. Storage & transport: Improper storage can cause damage and scratches before purchase.
Summary: The susceptibility to scratches mainly depends on the surface treatment and everyday handling.
As a supplement: Studies and product specifications show that melamine resin-coated particle boards usually have a foil thickness of less than 1 mm (0.04 inches). The sensitivity to scratches depends greatly on the hardness of the foil, which is determined by its composition and manufacturing processes. IKEA has deliberately introduced foils with improved scratch resistance in new product lines. At the same time, it should be noted that mechanical stresses, such as more aggressive sanding or sliding of objects, can damage even the most durable foil. Proper handling is therefore always essential.
Alina67 schrieb:
IKEA has intentionally introduced films with improved scratch resistance in new product lines That’s interesting, so it might be worth considering newer models if you plan to replace your shelf. Are there official labels for this at IKEA? I’m not very familiar with this.
naujon schrieb:
Scratch susceptibility mainly depends on the surface treatment and everyday handling. I had thought the same, but I couldn’t really notice much difference between my shelf being matte or glossy – visually, they looked very similar.
Gino38 schrieb:
Light-colored surfaces typically show scratches more than dark finishes That fits well since mine is quite light.
My idea now is to buy a protective film that can be applied almost invisibly – has anyone had experience with this? Does it affect the usability or look of the surface?
