ᐅ What are the effects of incorrect assembly on Ikea BRIMNES furniture?
Created on: 7 Dec 2024 09:17
Nasepau
I have a question and hope to get some opinions and experiences here in the forum: How does incorrect assembly specifically affect Ikea BRIMNES furniture?
I have read and experienced myself that improper assembly can lead to various problems, but I would like to understand the specific consequences this could have with the BRIMNES range. For example:
- Are stability and load-bearing capacity significantly affected?
- Are there typical points where errors become especially critical?
- What do damage resulting from these issues usually look like?
- Can assembly mistakes significantly reduce the furniture’s lifespan?
I also want to know if small errors are often only noticed on closer inspection, or if problems generally appear quickly and clearly.
Thank you for your assessments and experiences!
Dilen schrieb:
Nasepau, have you already had problems with a specific piece of furniture?Yes, exactly. I assembled a Brimnes shelving unit where I apparently screwed one side incorrectly – the back panel was not perfectly flush, which causes the entire shelf to wobble slightly. After some use, one of the screws has loosened a bit.
I’m specifically wondering if this could affect the shelf’s lifespan or if it’s generally not a problem as long as I tighten the screw again.
Nasepau schrieb:
I’m specifically wondering if this could affect the shelf’s lifespan, or if it’s generally not a problem as long as I tighten the screw again.As long as the screw is tightened properly and the back panel is fitted correctly, the issue is usually minimal.
However, continuous wobbling can wear out or damage the material around the screw over time.
My advice: Check all the joints carefully. You might want to disassemble the shelf briefly and reposition the back panel. This will improve stability and significantly extend the shelf’s lifespan.
flo-Theres8 Dec 2024 09:02A small addition from me: With furniture like BRIMNES, it is quite possible that even slight incorrect assembly can lead to minor material stresses, which over time may cause cracks or deformations.
These occur especially when parts are not perfectly aligned and are subjected to constant tension or pressure. Unfortunately, this can only be prevented by correct assembly.
Therefore, if in doubt, a complete rebuild is always worthwhile, especially if the piece of furniture serves an important function.
flo-Theres schrieb:
With furniture like BRIMNES, it is quite possible that even slight incorrect assembly can cause small stresses in the material, which may lead to cracks or warping over time.I would like to emphasize and add to this: The interaction between particleboard and plastic fittings can be particularly sensitive.
Additional assembly tips:
- Use a cordless drill with torque control
- Regularly check the angles during assembly with a set square or protractor
- Avoid overstressing individual joints
This way, you can prevent such material stresses from developing in the first place.
