ᐅ What should be considered when reassembling IKEA BRIMNES furniture after moving?
Created on: 8 Jul 2022 08:37
irvinepu
irvinepu
8 Jul 2022 08:37
Hello everyone, I am currently planning to move my Brimnes furniture from IKEA and want to make the reassembly at the new location as efficient and error-free as possible. From your experience, what are the most important factors to consider when reassembling IKEA BRIMNES after a move? I am especially interested in tips on disassembly, storage before reassembly, potential problem areas during assembly, and recommendations to avoid damage or mistakes. I would appreciate any detailed and practical information, as I want to prepare thoroughly to avoid unpleasant surprises later.
praWarre69
8 Jul 2022 09:42
Good morning and welcome to the forum! 😄 I believe the fun of rebuilding shouldn’t be lost, even when it gets tricky at times. My first tip: always pack all screws, dowels, and parts into clearly labeled bags so you don’t lose anything. The connecting pieces in the BRIMNES are often quite small, so it’s easy to overlook something. When assembling, take your time and follow the instructions carefully, even if it sounds boring. Using a cordless drill on medium setting will help you work faster – but be careful not to overtighten, as boards can easily crack. For storage, it’s better to lay parts flat and avoid stacking heavy items on top. Good luck, and feel free to share how it went!
daalessio
8 Jul 2022 11:08
As a general recommendation, before disassembling the BRIMNES system, carefully inspect the condition of the parts and document any damage. This will make it easier to check everything during reassembly. It is important that all fasteners (screws, clips, etc.) are gathered and organized. If the furniture has been assembled for several years, the connection holes may be damaged or worn out – be cautious here, as looseness can lead to instability. Another point to watch out for is the plastic dowels, which often break if removed incorrectly. For the assembly, I recommend downloading the instruction manual if it is no longer available. This can significantly reduce errors.
Charles
8 Jul 2022 13:17
My tip: Label the individual components after disassembly, for example with small stickers or markings, to make reassembly easier later on. With BRIMNES, the back panel is often a weak point—it can easily warp or get damaged during transport. Make sure to store it flat and protected. Also, use enough space and good lighting for assembly so you can clearly see the small parts and, above all, the alignment of the boards and connection points.
Kukar
8 Jul 2022 14:52
Disassemble everything, collect screws in bags, and store components flat. Handle the back panel carefully, do not bend it. Keep the instruction manual at hand. Do not tighten screws too much.
Ellis
8 Jul 2022 16:12
Important: When dismantling, do not unscrew the screws completely; often it is enough to loosen them. This helps prevent the holes from becoming worn out. It is also advisable to store attachments such as drawers or doors separately to avoid scratches.
