Hello everyone, I would like to know how to securely attach IKEA Malm dressers to the wall to prevent them from tipping over. Specifically, I am interested in which mounting materials are recommended, whether different types of anchors and screws are needed depending on the wall type, and the best approach for walls made of drywall or brick. I want to consider all relevant safety aspects because I have small children at home. Is there anything else to keep in mind when placing the dresser on an uneven floor? Thank you very much for your informed advice!
In summary for all readers here:
- Determine wall type before fastening
- Use appropriate anchors (drywall anchors vs. masonry anchors)
- Screws must penetrate at least 70 mm (3 inches) deep into the wall
- Align the dresser carefully, ensuring it stands on a level surface
- Attach safety brackets properly and secure them firmly in multiple places
- Consult a professional if unsure
This ensures a reliable hold for the Malm dresser and prevents tipping accidents.
Good morning, a further note, specifically regarding load distribution:
For drywall partitions, it is recommended to install metal mounting plates or plywood panels behind the wallboard. These are fixed over a large area and provide a solid base for the anchors. Ideally, this is considered during the house construction or renovation, but it is often missing in many older apartments.
For those who cannot retrofit, it is best to use heavy-duty anchors that increase the load-bearing surface.
A very good guideline – this ensures that the screws do not loosen from the substrate even under tension and stress, for example from children.
RETRAVIS schrieb:
Screws require at least 70 mm minimum depth in the wall
Finally, a note on maintenance and follow-up inspection:
Because screws and anchors can loosen over time due to temperature changes and stress, I recommend checking the fastenings every few months and tightening them if necessary. This is especially important in households with children who often hang on or move the furniture.
Before rechecking, carefully test the stability of the dresser. Slight wobbling indicates loose screws.
This will keep the Malm dresser secure over the long term, without any surprises.
