ᐅ The Malm dresser squeaks when closing – how I love these pieces!
Created on: 29 Sep 2024 18:34
U
uspi38
Hello everyone, I have owned the popular Malm dresser from IKEA for some time now and am generally satisfied with the quality and design. However, I am bothered by a persistent squeaking noise that occurs when closing the drawers. I have tried to understand why this happens, but I suspect it is due to the interaction between the metal slides and the rollers.
I am especially interested if anyone has had similar experiences and what solutions or maintenance tips can help to eliminate the squeaking permanently. I would also appreciate recommendations on how to keep the Malm dressers in good condition despite this noise – I love these pieces but want to maintain them well.
Thanks in advance for your help!
sanjon schrieb:
Sometimes they squeak when they are slightly misaligned That sounds plausible, as I sometimes feel that the drawer doesn’t run perfectly straight.
Lorukeo schrieb:
Less is more. Too much lubricant leads to dirt buildupI will keep that in mind. Regarding misalignment: Is there a simple way to adjust Malm dressers to improve this? Or do the drawer slides need to be replaced if it happens repeatedly?
I can totally relate to this problem – even if you love a piece of furniture, an annoying squeak can be very frustrating. When I first got my Malm dresser, the noise bothered me as well. After thorough cleaning and replacing a single drawer roller, the noise stopped.
It’s worth putting in the effort because otherwise, the dresser quickly loses its charm. And a fully functional piece of furniture simply brings more joy 🙂
If the squeaking comes back, I always find it helpful to check all the screws again, as small tensions can develop through regular use.
uspi38 schrieb:
a step-by-step guide would be greatHere is a brief guide:
1. Fully pull out the drawer.
2. Carefully check the drawer slides on the dresser to see if they are properly aligned. Tighten any loose screws with a screwdriver.
3. If the drawer slides can be removed (usually with a small metal tab or clip), take them out and clean them.
4. Thoroughly clean the slides and drawer rollers with a lint-free cloth.
5. Then apply silicone spray sparingly.
6. Reassemble everything and test the drawer.
Important: Do not forcefully pull or lever. The components can be fragile depending on their age.
If you can provide more details about the exact model (dresser height, number of drawers), I can give you more specific advice.
