Hello everyone, I would like to know how to securely attach IKEA Malm dressers to the wall to prevent them from tipping over. Specifically, I am interested in which mounting materials are recommended, whether different types of anchors and screws are needed depending on the wall type, and the best approach for walls made of drywall or brick. I want to consider all relevant safety aspects because I have small children at home. Is there anything else to keep in mind when placing the dresser on an uneven floor? Thank you very much for your informed advice!
I would like to add that when assembling the Malm dresser, it is essential to correctly use the mounting brackets at the top of the back of the dresser. These brackets should ideally engage with wall anchors to prevent the dresser from tipping forward under load.
A step-by-step approach:
1. Align the wall mounts and drill holes (matching the anchor type).
2. Insert anchors carefully, ensuring they are straight and not over-tightened.
3. Screw into the anchors and attach the brackets to the dresser.
4. Hang the dresser onto the wall brackets and secure it with screws.
For drywall, it is recommended to use backing, such as a wooden panel or a broad reinforcement behind the wall, to better distribute the load.
Exactly, this is crucial for stability.
RETRAVIS schrieb:
Screws should penetrate at least 70mm (2.75 inches) into the wall
It is very important to carefully align the dresser before installation. If it is attached to the wall at the back but wobbles at the front, even the best screw won’t help much. 😉
A small tip: Attach some felt or rubber pads under the front feet to ensure the dresser stands firmly and doesn’t wobble.
Also a good idea: If children like to climb on it, it’s best to secure the fastenings from above so nothing can be accidentally loosened. 😉
One more consideration: the installation height of the dresser affects safety. Especially if it is higher than about 1 meter (3 feet 3 inches), the risk of tipping increases. Therefore, always use the original mounting brackets and, if possible, add additional safety devices.
It is also important to ensure sufficient distance from window frames, door jambs, and possibly ventilation slots when drilling, so that the wall fasteners sit properly and do not lose stability due to screws that are too short.
Even contact with the floor increases overall stability, so be sure to use leveling pads.
Teogau schrieb:
Are there any additional things to consider when placing the dresser on an uneven floor?
One more note on child safety: There are special furniture wall anchors that can be attached to the side of a dresser if it is not possible to fix the back panel directly to the wall (for example, due to thin material or unusual wall conditions).
These anchors use a strong strap that essentially holds the dresser to a wall hook, preventing it from tipping over in an emergency.
Anyone with young children should definitely try all available methods to prevent furniture from tipping—not just rely on the screws provided.
I just read that many accidents are caused by improperly secured furniture, especially involving small children. So take your time with the installation – being nervous or rushed can do more harm than good.
I found that the most helpful too, as our dresser used to slide around otherwise, which made it feel unstable.
It’s completely fine to ask experienced friends for help or to hire a professional for securing the furniture if you’re unsure. Safety comes first!
TAUPLO schrieb:
A small tip: stick some felt or rubber pads under the front feet
