Good morning everyone, I have several drawers in my Ikea Pax wardrobe with fronts and runners that have visible damage from frequent use and occasional overloading. Specifically, there are cracked drawer fronts, stretched-out slides, and in some cases, drawers that get stuck and can no longer be opened or closed without applying force.
Does anyone have experience with how to repair such damage as effectively as possible without having to replace the entire drawer or wardrobe? Are there proven materials or replacement parts that fit, or are there tricks—such as tightening or replacing the slides—that can help restore functionality in the long term?
I would appreciate well-structured advice that thoroughly covers the effort involved and potential pitfalls in the repair process.
Garry schrieb:
I recommend checking all screw connections and tightening them if necessary – loose screws are one of the most common causes of sticking drawers. That’s an important point, thank you for the reminder. I have since adjusted several screws, especially on the front and the side profiles. But what about potential material fatigue that could cause, for example, the front to crack? Would reinforcement from the inside with thin wooden strips help, or perhaps a repair using epoxy resin? I don’t want to just patch it up temporarily, but aim for a long-lasting improvement.
Reinforcing from the inside with thin wooden battens is advisable and lasts longer than epoxy resin on smooth surfaces. Epoxy can help if you do not want to replace the front, but the mechanical stress remains. For lasting stability, additional screws and battens are better.
PECLARISSA22 May 2022 10:13tansan65 schrieb:
I don’t want to just do a quick fix, but aim for a long-lasting improvement. You’ve got it exactly right! For a durable repair, the combination of internal reinforcement and suitable replacement drawer slides is ideal. In the meantime, you can regularly clean and lightly lubricate the drawers to minimize wear. A bit of maintenance never hurts and makes future repairs much easier.
Looking at it casually: repairing Pax drawers can sometimes feel like a little DIY adventure. The important thing is to clearly understand what is broken from the start. For the fronts, I also find that regular craft glue often isn’t strong enough. It’s better to glue or screw in small brackets. And when you buy the drawer slides, make sure you get the right version – there are different types for light or heavy drawers. That way, the repair can be done with a bit of ease. Good luck!
