Good morning everyone, I have several drawers in my Ikea Pax wardrobe with fronts and runners that have visible damage from frequent use and occasional overloading. Specifically, there are cracked drawer fronts, stretched-out slides, and in some cases, drawers that get stuck and can no longer be opened or closed without applying force.
Does anyone have experience with how to repair such damage as effectively as possible without having to replace the entire drawer or wardrobe? Are there proven materials or replacement parts that fit, or are there tricks—such as tightening or replacing the slides—that can help restore functionality in the long term?
I would appreciate well-structured advice that thoroughly covers the effort involved and potential pitfalls in the repair process.
To effectively repair damaged PAX drawers, the individual components should be identified first: the drawer front, drawer box, runners, and the guiding system. In case of cracks in the front panel, repair with wood filler or replacement of the front is recommended, depending on the material. The runners can usually be replaced with original spare parts, as they have standardized dimensions. It is important to carefully realign the guide rails after installation to ensure smooth sliding. If the drawers are warped, it is advisable to disassemble them and, if necessary, reposition the components. Overall, repair is only recommended if the basic structure of the drawer box is still intact.
nonpra schrieb:
Ikea offers replacement parts for the runners, which are easy to swap out. Exactly! I’m quite fond of the PAX drawers, but once the runners wear out, pulling them feels like a small workout. If you’re replacing the runners, it’s important to pay attention to the quality of the replacement parts. Sometimes, not all are equally durable. A small tip: after replacement, applying a thin layer of silicone on the runners helps them glide more smoothly – it really saves frustration when opening. 😉
To restore the stability of the drawer fronts, it is often worthwhile to reinforce the joints from the inside with additional angle brackets without affecting the appearance. If the drawer slides are slightly bent, they can be carefully straightened with pliers before installation. I recommend checking all screw connections and tightening them if necessary – loose screws are one of the most common causes of sticking drawers.
toril schrieb:
The drawer slides can usually be replaced with original spare parts since they have standardized dimensions. Additionally, it is important to measure precisely before purchasing replacement parts because Ikea has installed different variants depending on the production year and model. Although an incorrect drawer slide set may look fitting, it often compromises the load capacity and durability of the drawer. I also recommend using a cordless drill with torque control to avoid over-tightening the screws and to protect the material.
