ᐅ How can you protect the surfaces of Ikea Brimnes furniture during use?
Created on: 10 Jan 2024 19:27
Gi-chenHello everyone,
I have been using the Ikea Brimnes furniture system for some time now, especially the surfaces on dressers and cabinets. I have noticed that with daily use, slight scratches, stains, or dull spots appear, even though I try to handle them carefully.
I am particularly interested in how to best protect and maintain the surfaces of Ikea Brimnes furniture so they stay looking good for a long time.
I would like to know if there are specific cleaning products or protection methods that have proven effective, how to prevent stains and scratches, and whether materials like special felt pads or protective films might be a good option.
My furniture is not exposed to direct sunlight, but I have pets and sometimes small children in the house – which of course makes use more challenging.
Looking forward to your tips, experiences, and recommendations!
Hello Gi-chen,
I’ll try to approach this topic in a structured way, as I have used several pieces of furniture from the Brimnes series for a long time and have experience with their care.
1. Cleaning Products: Most Brimnes surfaces are laminated, meaning they are not solid wood but coated with melamine. Therefore, you should avoid using harsh cleaners or abrasive materials. Mild detergent solutions or special furniture cleaners for laminated surfaces work best. Avoid excessive moisture.
2. Protection Against Scratches: If you use the furniture as a chest of drawers, I highly recommend felt or foam pads under decorations, vases, or other items that could scratch. Protective films or transparent table protectors are also a good idea, especially on frequently used surfaces.
3. Stains and Dull Areas: I suggest wiping up spills as quickly as possible with a soft, damp cloth. Avoid rubbing or scrubbing hard. For dull spots, there are specific furniture polish products available, but make sure they are suitable for this type of material.
4. Long-Term Care: The furniture should ideally not be placed in direct sunlight to prevent fading. Regularly wiping with a dry cloth in daily use also helps prevent dust from dulling the surface.
I hope this helps, and feel free to ask if you have any more questions!
Hi Gi-chen,
I know this well, especially when you have small children, dealing with surfaces can be quite challenging.
I can only agree with that—many scratches were removed or prevented because of this in our home.
I’ve also noticed that scratches often happen due to moisture, especially when children touch the furniture with wet hands or when something wet is placed on it. That’s why I often keep placemats or small pads nearby.
Sometimes cleaning feels tricky because you don’t want to cause more damage. That’s why now I use only gently damp microfiber cloths and wipe lightly—no pressure, no harsh cleaning agents.
I also considered a clear protective film, but I haven’t tried it yet because I’m worried the surface might look unattractive or the film might peel off. Does anyone have experience with this?
In any case, I’m glad we’re discussing this because I often think about what else can be done to keep the furniture looking nice and prevent it from wearing out too quickly.
LOGEMIN schrieb:
If you use the furniture as a dresser, I definitely recommend felt or foam pads under decorations, vases, or other items that could scratch.
Regarding the protection of laminated surfaces like those on Ikea Brimnes, I can add the following:
- Protective films can indeed be useful if they are high-quality and precisely fitted. There are specially designed transparent, thin protective films for furniture that are UV-resistant and non-slip. This helps protect against scratches and stains without significantly changing the appearance.
- However, careful and dust-free application is important to avoid air bubbles and poor adhesion. I would recommend testing this first on a less visible area.
- I also suggest regular but gentle cleaning using a neutral cleaner. When choosing cleaners, make sure they do not contain solvents or harsh ingredients that could damage the film.
- Minor scratches can sometimes be repaired with special repair kits for laminated surfaces, which are available at hardware stores or furniture retailers.
Just as an addition: Consistently good ventilation also helps prevent moisture from quickly damaging the film or surfaces.
If you would like more technical details or product recommendations, I’m happy to assist.
