ᐅ How can you gently clean Ikea Hemnes furniture when you have pets?
Created on: 26 Jun 2017 08:37
ChenfraI have a rather specific question: How can Ikea Hemnes furniture be cleaned gently when you have pets at home? My cats are very active, and I’ve noticed that some cleaning products not only have an unpleasant smell but can also damage surfaces or leave residues that might be harmful to animals.
I am therefore looking for methods or products that both protect and clean the solid wood furniture while also being safe for pets. If anyone has experience with natural cleaners, special care products, or removing pet hair and scratch marks, I would greatly appreciate detailed tips.
Which products do you consider best suited, and are there any particular procedures to follow to protect both the furniture and the health of the animals?
Hello Chenfra, your question is very precise, which is very helpful. Basically, when dealing with Hemnes furniture, you should avoid using aggressive or abrasive cleaners, as the wood has an oiled or lacquered surface that can be easily damaged. For pet hair, I recommend using a microfiber cloth or a special rubber glove that allows you to collect the hair without scratching. For general cleaning, it is best to use lukewarm water with a mild biodegradable dish detergent to avoid leaving harmful residues on the wood. Afterwards, wipe immediately with a dry, soft cloth to prevent moisture absorption. Be careful with oils or wax polish: check their compatibility with your pets, as natural oils are often safe, but aggressive substances should be avoided. If you like, I can also put together a short list of suitable products.
lochen schrieb:
For the actual cleaning, it’s best to use lukewarm water with a mild, eco-friendly dish soapThat’s a good starting point, but I’d like to add a bit more detail: Hemnes furniture is made from solid pine wood, which means the wood is very sensitive to moisture and mechanical stress. With pets, there’s also the factor of scratches and dirt, for example from cat paws with soil or dust. My advice is to first remove dust and pet hair from the surface using a soft broom or specialized pet hair rollers. Then clean the furniture spots only locally with a slightly dampened cotton cloth and a very mild cleaner without alcohol or ammonia.
Be careful not to leave any puddles of water on the furniture, as the wood can swell and later develop cracks. After cleaning, you should immediately wipe the surface dry with a dry cloth. A special wood cleaner or care product, preferably free of fragrances and chemical preservatives, helps to maintain the protective layer. Additionally, I would recommend regularly touching up small scratches with color-matched furniture wax or wood filler.
I’m curious: What exactly do your furniture pieces look like (lacquered or oiled), and how severe is the dirt caused by the animals? Are there particular areas that bother you the most?
The right cleaning method really also depends on the condition and level of use.
Chenfra schrieb:
How can Ikea Hemnes furniture be gently cleaned when you have pets at home?From a technical perspective, the following should be considered: Hemnes furniture is generally made of solid pine wood, usually treated with water-based varnish or oil. These finishes are generally durable but require specific care to maintain the wood’s texture and to prevent damage from moisture or abrasion.
I recommend the following approach:
- Regularly remove dust and pet hair using microfiber cloths or rubber gloves to avoid mechanical damage such as scratches.
- Use a mild, pH-neutral cleaning agent without aggressive substances like ammonia or alcohol that can harm the surface.
- Apply the cleaner in a heavily diluted form and wring out the cloth well afterward to avoid excess moisture.
- Immediately wipe the surface dry with a soft, dry cloth to prevent water spots and swelling.
- For oil-treated surfaces, regular refreshment with a food-safe wood oil can be done to protect and nourish the wood.
Additionally, it is important to check the ingredients of cleaning products carefully; neither fragrances nor preservatives should leave residues that could be toxic to pets. If you monitor where your cats move on the furniture, it helps to clean and maintain those areas more frequently.
I hope these facts are helpful to you.
