ᐅ How do you fix jamming issues with Ikea Platsa drawers?
Created on: 31 Oct 2015 08:17
fibla
fibla
31 Oct 2015 08:17
Hello everyone, I have a problem with my Ikea Platsa drawers that keep sticking when I pull them out or push them in. Specifically, the issue involves the drawer front rails, which on some of my units catch and do not slide smoothly. I have already checked that the drawer is properly installed and that the rails are clean, but this only helps to a limited extent. Sometimes there is a slight creaking sound, or more force is needed. Are there any proven tips or methods to effectively eliminate or at least reduce sticking issues with Ikea Platsa drawers? I look forward to hearing about your experiences and advice, including any suggestions for special adjustments or installation tips.
JEREMIAH38
31 Oct 2015 09:03
Hello fibla, that sounds really frustrating. I’ve also had issues with my Platsa drawers sticking, and to be honest, I was quite often at my wit’s end. Sometimes it helps to completely remove the rails to check if they’re installed correctly or if there are any small foreign objects blocking the way. What worked for me as well was gently lubricating with a dry lubricant (not oil, as that attracts dust). It’s important to fully remove the drawer before checking the track. How well are your sliding rails installed—are they perfectly vertical and parallel? I ask because even a slight tilt can cause these kinds of problems. Hang in there, it will definitely work out! How many units are affected in your case?
leebi7
31 Oct 2015 09:45
Hello fibla, I have read your description and would like to respond in more detail because the Platsa drawers may seem sturdy, but they have some particular features in their mechanisms that you should know to effectively fix jamming issues. First of all, I recommend the following step-by-step approach:
- Remove the drawers: Pull the drawer out completely and remove it if possible. This makes it easier to check the slides.
- Inspect the slides for irregularities: Sometimes there are small plastic tabs or packaging remnants that prevent the drawer from sliding fully.
- Check alignment: The slides should be mounted perfectly straight and parallel – even a few millimeters (inches) tilt can cause misalignment. Use a spirit level if necessary.
- Clean: Remove dust and lint from the guide rails with a dry cloth and, if needed, a brush.
- Lubrication: Use silicone spray or a dry lubricant. Never use oil, as it attracts dust and often worsens the problem.
Additionally, you should check whether accessories like stoppers or spring mechanisms in the drawer frame are correctly positioned. They ensure that the drawer locks properly and closes softly.
A small technical note: I have often noticed that the rear slide attachment on some models is not entirely stable. Loose screws can cause jamming. Also, make sure the load is evenly distributed if there are many heavy items in the drawer.
If you want, I can help you describe the individual components in more detail or suggest useful tools to check everything thoroughly. What exactly is your situation? Have you already tried a specific method?
kyledeo
31 Oct 2015 10:12
The Platsa drawers used to stick for me until I tightened all the screws on the runners. Then I cleaned everything and applied silicone spray to the rails. Important: Make sure to insert the drawer correctly until you hear a clear click.
Joshbe
31 Oct 2015 11:37
Regarding issues with sticking in Ikea Platsa drawers, a misalignment of the rail brackets from their intended position can be the cause.
Precise installation according to the instructions is essential. For example, ensuring the guide rails are parallel is important – a deviation of just 1–2 mm (0.04–0.08 inches) can cause noticeable obstruction.
It is also recommended to check the drawer mechanism for wear or bent components.
A proven method is to clean all sliding areas from dust and dirt and to use a suitable dry lubricant to reduce friction without attracting dirt.
If uncertain, later adjustments of the rail brackets using appropriate shims or fine alignment can help. Checking and, if necessary, tightening all mounting screws is also part of proper maintenance.
fibla
1 Nov 2015 07:54
leebi7 schrieb:
If you want, I can help you describe the individual components more precisely or suggest which tools are useful to check everything accurately. What exactly is your situation? Have you already tried a specific method?
Thanks, that sounds very helpful! Actually, I have only done a basic check so far. I haven’t tightened the screws yet, but it seemed to me that the rails are already fairly straight, although I haven’t used a spirit level to align them. One method I tried was pulling the drawer out and gently moving it without removing it, to test if the sliding direction changes, but that wasn’t very conclusive. Carefully feeling, I noticed the rear of the rail has a slight play. How would you recommend checking the screws precisely and using a spirit level effectively without disassembling the furniture?
