ᐅ What is the best way to clean Ikea Pax wardrobes with a wood finish?
Created on: 30 Dec 2015 18:03
clemens51
clemens51
30 Dec 2015 18:03
Hello everyone, I have a question about the proper cleaning of my Ikea PAX wardrobe, which has a wood-effect surface. It is important to me that the cleaning products and methods do not damage or discolor the surface. At the same time, dust and grease should be effectively removed without harming the material. What is the best way to clean an Ikea PAX with a wood-effect finish, which products are recommended, and which should be avoided? Are there any special tips for removing fingerprints or stubborn stains? I would appreciate any helpful and practical advice!
DUVIN
30 Dec 2015 18:15
You can use a damp cloth with mild dish soap. Important: Not too wet to avoid swelling. Afterwards, wipe with a dry cloth. Do not use harsh cleaners, as they will damage the surface.
emmaju
30 Dec 2015 19:07
Hello! Cleaning Ikea PAX units with wood veneer is not complicated, but it should be done gently to preserve the surface finish. It is recommended to regularly remove dust using a soft, dry cloth or a duster. For general dirt, you can use warm water with a mild, neutral detergent (e.g., pH-neutral soap or mild dish soap) – make sure to wring the cloth well to avoid leaving moisture on the wood veneer. Afterwards, wipe the surface with a dry microfiber cloth to remove any water residue. For more stubborn fingerprints, a slightly damp cloth, possibly with a few drops of diluted vinegar solution, can be effective without damaging the material. Do not use abrasive cleaners, aggressive chemicals, or excessive water. This way, the wood veneer will stay looking good for a long time!
ANFIKE
30 Dec 2015 21:20
In short: Use a damp microfiber cloth with mild dish soap, wring it out well, avoid soaking it with water, and wipe dry afterward. This method effectively removes fingerprints.
glapu
30 Dec 2015 22:41
I would like to add: Always wipe in the direction of the wood grain to prevent streaks. Also, avoid using abrasive sponges to protect the surface from scratches.
piBenedi41
31 Dec 2015 07:36
I also find the topic of caring for PAX with a wood finish interesting – I initially had concerns about stains, especially with children in everyday life.
I can confirm that, but I also tried using a few drops of olive oil on a dry cloth instead of dish soap to protect the surface a bit afterward and enhance the wood look. It works quite well, but be very sparing and polish thoroughly!
It is important for me to avoid damage, and I have noticed that cleaning more frequently with smaller amounts helps, rather than doing a deep clean rarely. Otherwise, I feel the surface eventually becomes dull.
