ᐅ What is the best way to clean Ikea Pax wardrobes with a wood finish?
Created on: 30 Dec 2015 18:03
clemens51
Hello everyone, I have a question about the proper cleaning of my Ikea PAX wardrobe, which has a wood-effect surface. It is important to me that the cleaning products and methods do not damage or discolor the surface. At the same time, dust and grease should be effectively removed without harming the material. What is the best way to clean an Ikea PAX with a wood-effect finish, which products are recommended, and which should be avoided? Are there any special tips for removing fingerprints or stubborn stains? I would appreciate any helpful and practical advice!
Hello! For gentle cleaning of wood-look surfaces on Pax, I recommend first vacuuming dust off with a soft brush. After that, use a lint-free, soft cloth that is only lightly dampened.
That is very accurate. Also, avoid using products containing ammonia or alcohol, as these can damage the finish.
If you have stains that are hard to remove, try a mixture of water and a little vinegar first. But test it on an inconspicuous spot beforehand to ensure the surface does not discolor.
emmaju schrieb:
For general dirt, you can use warm water with a mild, neutral cleaning agent (e.g., pH-neutral soap or gentle dish detergent)—just be sure to wring the cloth well to avoid leaving moisture on the wood-look surface.
Here is a summary and a brief cleaning tutorial:
1. Remove dust with a soft, dry, or slightly damp microfiber cloth.
2. For regular dirt, dampen a cloth with warm water and a small amount of mild dish soap, then wring it out thoroughly.
3. Wipe with the damp cloth following the direction of the wood grain.
4. Immediately wipe again with a dry microfiber cloth to prevent residual moisture.
5. For grease stains, gently treat with a grease-dissolving agent (mild dish soap), then allow to dry well.
6. Fingerprints can also be removed with a little vinegar water, but test first.
7. Never use harsh or abrasive cleaners to avoid scratches.
A common mistake is over-wetting the cabinet with water – this causes the wood-look to swell.
Finally, a care tip: regular, gentle wiping extends the surface’s lifespan and preserves its appearance.
If stains are stubborn despite this, it is better to treat them early rather than scrubbing hard.
