mu-galen338 Nov 2023 16:37Hello everyone,
I would like to start a specific and detailed discussion about how to effectively prevent scratches on an IKEA Billy bookcase when moving it.
I am especially interested in practical measures that have proven effective in avoiding both minor and more noticeable scratches on the veneered surface. This includes both the physical handling during the move and the use of protective materials.
Are there any special tools or techniques for gripping or supporting the bookcase to protect the delicate edges and surfaces? And do preventive sealants or special films help at all?
I look forward to your tips and experiences, to learn from solutions that really work in everyday situations and are not just theoretical suggestions.
SETHBLA schrieb:
It’s best to completely clear out the Billy shelfClearing it out is indeed a very important factor, as the weight is significantly reduced when moving it, allowing for more controlled handling.
I also recommend using felt pads or thin furniture sliders under the edges to prevent floor scratches and to make moving it easier.
When lifting, be careful not to pull on the side panels, as they are made of particleboard and can be easily damaged – it’s better to grip the bottom panel or back panel if possible.
Another preventative measure is wrapping the shelf edges with foam edge protectors. This protects the surface from direct impacts and scratches during indoor transport.
mu-galen33 schrieb:
how to handle or support the shelf to protect the delicate edges and surfaces?A very good point. I recommend always lifting the shelf at its strongest points – that is, at the back panel or the base, where the joints are most secure. The side panels are the most vulnerable to damage.
Additionally, wrapping the shelf in a thick cloth or blanket can help prevent abrasion on the surfaces. If there is only one helper, it can be useful to place the shelf on a blanket or padding and carefully slide it instead of lifting it.
In my experience, sealants or films offer only limited protection since the surface is mainly affected by mechanical impact. Therefore, careful handling and avoiding direct contact with rough or hard materials is much more important.
