Hello everyone, I plan to disassemble my BILLY shelf to make it easier to transport. I want to avoid damaging any parts, whether it’s scratched wood surfaces, torn-out drill holes, or bent metal fittings. I’m especially interested in which tools are best suited for this and if there are specific techniques to prevent damage to the connectors. Are there any experiences on how to remove screws and dowels most gently without compromising stability? Any advice on potential weak points to watch out for would also be very helpful. Thanks in advance for your tips!
The most important thing first: Always unscrew screws completely and avoid pulling them out at an angle. It is best to use an appropriate Phillips or flathead screwdriver to prevent damage to the screws. To loosen anchors, occasional gentle tapping with a rubber mallet can help to carefully loosen them.
sanjon schrieb:
Always fully unscrew screws and do not pull them out at an angle. That is certainly correct, but people often forget that the BILLY shelf is a mass-produced item not designed for frequent disassembly. So, anyone expecting the dowels to come out intact every time is dreaming. I would argue that anyone who regularly takes apart a BILLY shelf should have replacement dowels and screws on hand.
Furthermore, I believe you shouldn’t worry too much about minor scratches. After a few years, a shelf like this simply won’t look brand new anymore. Much more important is to stay calm and proceed patiently, step by step. Trying too hard to save everything often causes more damage in the end.
First of all, thanks for the interesting contributions so far. To truly avoid damage when disassembling BILLY, I recommend a systematic approach, which I will gladly explain:
1. Preparation: First, identify all screws according to their position and check for slipping on the screw head. Ideally, use a ratcheting screwdriver that allows for clean and consistent pressure.
2. Loosening screws: Turn the screws slowly and without hurry, never with force – they often seize at the end. If a screw stubbornly resists being turned, it helps to treat it lightly with a few drops of WD-40 and let it sit briefly before trying again.
3. Handle dowels and wooden plugs carefully: Caution is necessary here. Dowels firmly connect the panels; pulling often meets strong resistance. Instead of pulling, gently pry between the panel and dowel with a thin levering tool (e.g., plastic spatula) to reduce clamping pressure.
4. Protect wooden surfaces: To avoid scratches, I recommend placing soft material (e.g., cloth or thin cardboard strips) between the tool and the surface, especially during levering work.
5. Step-by-step, controlled disassembly: It is important to loosen only as much as needed so the parts separate easily, rather than forcing or twisting with too much strength.
Finally: If specific weak spots, such as cracked panel edges or bent metal fittings, are already present, disassembly is more difficult. That is why great care is also required during assembly. If you like, feel free to add which tools you use exactly. What is your approach in practice?
