ᐅ How can you assemble Ikea HEMNES shelves to make them especially sturdy?
Created on: 23 Feb 2021 08:37
Reo30
Reo30
23 Feb 2021 08:37
I would like to start a comprehensive yet practical discussion here on the question: How can Ikea Hemnes shelves be assembled for maximum stability? It’s important to me not just to repeat the standard instructions, but to focus on specific techniques and tips that significantly improve stability, especially when using the shelves for heavy items or long-term storage.
I have already assembled a few shelves and noticed that, despite correct assembly, they don’t always feel as stable as expected. I am particularly interested in what additional measures can be taken during installation without major modifications, and how to address common weak points in the assembly.
Does anyone have experience with using extra fasteners, such as high-quality screws or wall anchors? Or is proper wall mounting the key factor?
Thanks in advance for your tips and advice!
taudi
23 Feb 2021 10:25
Good morning,
I would like to divide the assembly of Ikea HEMNES shelves into three practical steps regarding stability:
- Preparation: First, you should thoroughly check the installation location. A flat, level surface is essential. Errors such as unevenly placed shelves have a significant impact on stability.
- Careful screwing: The wooden panels in the HEMNES system do not tolerate screws being driven in too deep or at an angle. Be sure to pay attention to this.
- Wall anchoring: It is especially important to use the supplied fixing materials to secure the unit to the wall. Stronger anchors or screws can be used instead of the included ones if the wall allows it.
Additionally, it helps to check with a spirit level during assembly—especially for tall or wide models—to ensure everything is perfectly square. This evenly distributes forces and prevents the shelf from leaning.
Common mistakes I frequently see:
- Missing or incorrectly installed back panels
- Overlooking wall anchoring
- Screws that are either overtightened or too loose
Assembled this way, the HEMNES shelf provides reliable stability that remains solid even under load.
Tevin
23 Feb 2021 13:04
I would like to add: When it comes to the HEMNES shelving units, the wall connection is really crucial. The IKEA package typically includes simple plastic anchors and screws that work well for concrete walls but often don’t provide enough support for drywall.
A proven solution is to use appropriate expansion anchors or metal cavity anchors for drywall, which securely fix the shelving unit without damaging the wall. Especially in homes with children and high activity levels, these upgrades are highly recommended.
Additionally, the stability of the shelving unit can be improved by attaching small brackets or metal straps at the back, without affecting the appearance. It is important that the back panel is mounted cleanly and flush, as it also serves a structural purpose.
Finally, check that all screws are tightened carefully, but not too much, to avoid damaging the material.
Tause
24 Feb 2021 07:19
taudi schrieb:
Typical mistakes I keep seeing:
- Unused or incorrectly installed back panels
I would like to revisit this topic. Some users report that the back panel on the HEMNES shelving unit is often made of thin MDF or particleboard and barely contributes to overall stability. Are there any confirmed findings on whether the back panel really carries load under stress, or if it mainly serves to prevent lateral twisting?
Furthermore, I wonder if the internal wooden framework inside the unit (e.g., connecting rods or braces) plays a more significant role under heavy load.
In my opinion, for applications where stability is critical, it makes more sense to consider additional reinforcements—such as diagonally installed battens on the back or using angle brackets—rather than relying solely on the original back panel.
What are your thoughts?
RETRAVIS
24 Feb 2021 12:43
Tause schrieb:
I would like to revisit this point. Some users report that the back panel of the HEMNES shelf is often made of thin MDF or particleboard and hardly contributes to stability.
The back panel of the HEMNES shelf is indeed not designed to bear heavy loads but mainly serves to stiffen the shelf against lateral twisting (tilting). Its contribution to stability should therefore be understood as reinforcement rather than a load-bearing element.
Additionally, the original back panel is only glued or fixed with small nails, which limits its load capacity.
For increased stability, I recommend:
- Securing the shelf to the wall with high-quality anchors appropriate for the wall material
- Adding additional diagonal braces on the back if the shelf is subjected to high loads or vibrations
- Ensuring all joints are perfectly square to avoid shear forces
I have personally had good experience using small metal brackets in the inner corners to strengthen the connections.
In conclusion, the back panel should be seen as one of several stability elements, not as the sole guarantee of the shelf’s uprightness.
