ᐅ How can I use Ikea Besta flexibly for changing living situations?
Created on: 12 Apr 2016 10:23
alessand52A
alessand5212 Apr 2016 10:23I am considering getting the Ikea Besta system and would like to hear about your experiences: How do you use Besta flexibly when your living situation changes frequently? I am specifically thinking of situations like moving to smaller or larger apartments, renovations in rented flats, or temporary changes such as working from home and varying needs for storage and media furniture. I am particularly interested in how to design the system modularly and versatilely so that individual components can be easily added or replaced without having to buy everything new each time. What tips do you have for smart planning, practical combinations of elements, and which types of fronts, sizes, or accessories help you stay flexible?
The Besta is really like the Swiss Army knife of furniture – it fits almost anywhere and always looks great 😄. My tip: go for the open compartments, so you can easily combine decoration and storage. And with the doors, you quickly get a completely different look. Especially when you want a change of style fast, interchangeable fronts are worth their weight in gold.
When using Ikea Besta flexibly, the modular basic structure is especially important. The standardized widths (60 cm (24 inches), 120 cm (47 inches)) and heights (38 cm (15 inches), 64 cm (25 inches), 128 cm (50 inches)) allow for practical combinations suited to different room layouts. It is advisable to combine some basic modules with adjustable shelves and interior organizers. This makes it easy to adapt the internal layout of each unit. The use of slot systems for back panels and insert shelves enables simple updates when moving. For changing needs, additional cabinets and visible extensions are recommended. A clear plan is essential to determine whether the system will remain mostly static or be frequently reconfigured.
For sustainable and flexible use of the Besta system, I recommend at least these two basic principles: 1) Start with a basic module measuring 120x64 cm (47¼ x 25¼ inches) with adjustable shelves. The adjustable shelves allow for individual customization without having to disassemble everything immediately. 2) Complement the system with universal doors and drawers whose interiors can be quickly modified using dividers or inserts. It is important to pay attention to compatible fronts – Ikea ensures that the same parts can still be interchanged after several years. Technical details such as using soft-close hinges increase long-term comfort, especially with frequent use. If a home office is the focus, I recommend modules with cable outlets and a few sockets that can easily be passed through or added if you are handy. A critical question: How much space do you currently have, and what is the maximum you want to fit into a single module block? This way, size adjustments can be targeted more effectively.
alessand5212 Apr 2016 13:18fidasi schrieb:
If the home office is the main focus, I recommend modules with cable passages and a few power outlets that can be easily routed through or added later if you’re handy. Thanks, fidasi, that’s an important tip. Electrical planning can often be a stumbling block. My updated focus now includes flexible use as both media and office furniture. I have planned around 2.5 meters (8 feet) of wall space, but I might need to reduce it to 1.5 meters (5 feet) or expand it to about 3 meters (10 feet) depending on what’s possible in the apartment. Are there recommendations on which modules to acquire first to keep the base setup flexible? And how is the stability when combining several smaller modules?
