ᐅ How can I stabilize tall BILLY shelves to prevent tipping over?
Created on: 1 May 2018 09:13
tigaplo
I have some tall Billy shelves from IKEA at home that I regularly use to store books and files. Now I’m worried that these shelves could easily tip over if accidentally bumped, especially in households with children. My question is: What is the best way to stabilize these tall Billy shelves against tipping? Which measures and installation options are particularly effective and practical without affecting the appearance too much? I am interested in tips on the type of wall anchors, additional stabilizers, or other safety devices that make the most sense. Perhaps some of you have experience with this issue and can share your practical insights.
Thank you very much for your tips and advice!
Louie schrieb:
For drywall partitions, the usual screws and wall plugs are often not sufficient to securely anchor heavy furniture.Samir schrieb:
For drywall partitions, I recommend using toggle bolts or heavy-duty anchors.Thanks to both of you, that’s very helpful! I will check which types of anchors can be installed in my situation. Are there any tips for correctly installing such heavy-duty anchors, for example drill hole size or installation method? Or common mistakes to avoid?
Also, as recommended, I plan to place heavy items lower down. But can you estimate whether, in addition to wall fixings, it makes sense to add extra floor fixing?
Looking forward to more advice!
Hello tigaplo,
I would like to address your questions regarding hollow wall anchors and floor fixing:
1. Drill hole size: The drill hole size should always match the exact diameter of the anchor type you are using. Manufacturers provide this information on the packaging – for example, typically 8 mm (0.3 inches) for a metal anchor, or sometimes 10–12 mm (0.4–0.5 inches) for clip anchors.
2. Installation principle: It is important to drill the hole without overheating the drill bit (remove dust) and to insert the anchor fully and straight. With expansion anchors, the anchor expands as you tighten the screw, providing strong holding power in drywall.
3. Common mistakes: Using a drill hole that is too large or too small, improper insertion of the anchor, screws that are too short, or missing pilot holes for the screws can reduce the load-bearing capacity.
4. Floor fixing: If the shelving unit stands on a stable and level floor, floor fixing is usually not necessary. However, if the floor is uneven or unstable, a small floor anchor may be helpful, such as narrow brackets at the feet screwed into the floor (depending on floor materials). This is rarely required and often less visually appealing.
Generally, secure wall fixing combined with proper load distribution is sufficient.
PRA64 schrieb:
A secure wall fixing plus proper load distribution is usually sufficient.Great, thanks to all the experts here! I now have a pretty clear idea:
- For drywall wood stud walls, I will use special hollow wall anchors (toggle bolts or heavy-duty anchors), pay attention to the correct drill hole size, and ensure professional installation.
- I will secure the shelves with strong screws and brackets at the upper part of the wall.
- Heavy items will go at the bottom of the shelf, lighter objects on top.
- Floor fixings probably won’t be necessary in my case.
I will keep these tips in mind and get back if I encounter any specific problems during installation.
Many thanks for the detailed help – it’s really very insightful for me :-)
