I have the problem that my Ikea Hemnes shelves are not stable on my uneven wooden floor. Especially when I slightly shake them, you can clearly feel the wobbling – which is not ideal for larger shelves, especially when you put heavy books or decorative items inside.
The floor is not extremely tilted, but uneven enough that the shelf feet do not make even contact at every point. I have considered using some kind of pads or wedges, but I want to make sure the stabilization is permanent and secure, without damaging the shelves or affecting their appearance.
Does anyone have experience or tips on the best way to stabilize Ikea Hemnes shelves on uneven floors? Which tools, materials, or methods work particularly well here?
Thanks in advance for your help!
Hello Luca48,
I understand your problem well, as uneven floors often cause issues with furniture like the Hemnes shelving unit. The most important thing is to create a stable base that adapts to the floor’s unevenness while protecting the furniture from moisture or damage.
Here are some options I can recommend:
- Attach rubber or felt pads under the feet. These compensate for minor unevenness and protect the floor.
- For more significant floor unevenness, furniture wedges or shims made of plastic or wood can be used and placed individually underneath.
- Alternatively, flexible underlay pads can be used to even out small height differences.
- In some cases, self-adhesive plastic feet that allow a bit more flexibility may be helpful.
It is important to secure the shelving units to the wall afterwards, as this provides additional stability and prevents tipping.
Good luck, and feel free to reach out if you have any further questions!
Regarding the stabilization of Ikea Hemnes shelves on uneven floors, I would like to add some precise points:
- The shelves should first be accurately leveled using a spirit level to identify which feet need adjustment.
- For unevenness, special furniture shims made of plastic with adjustable height are suitable; they do not deform and remain stable over time.
- Felt pads of varying thickness can also help but are generally only appropriate for minor unevenness.
- According to Ikea safety guidelines, wall anchors must be installed and significantly contribute to stability.
- Avoid padding the feet directly with paper or cardboard, as these materials absorb moisture and deteriorate quickly.
This ensures long-lasting and safe stability without affecting the appearance or damaging the materials.
jaanda schrieb:
Avoid padding the feet directly with paper or cardboard, as these materials absorb moisture and wear out quickly.Good point! I once tried to compensate with old business cards, and the wobbling stopped at first – but after a few weeks, the cards were quite worn out and it started rattling again. 😅
What worked really well for me were small rubber pads that you can buy at a hardware store. They are very absorbent and cushion loads perfectly. And they’re hardly noticeable.
You can also try experimenting a bit with the feet supports – a little tip: for uneven surfaces, placing a small scrap of wallpaper under a foot often helps – nothing official, but it does make a difference.
Good luck with trying it out!
Julien schrieb:
For more significant floor unevenness, so-called furniture shims or wedges made of plastic or wood are suitable, which can be placed individually underneath.That makes sense. Do you have any recommendations on where to find furniture shims in various thicknesses or what to look for when buying them?
Also, I’m wondering if it’s possible to adjust the shelves from underneath, for example with adjustable feet? Or is it better to rely on fixed shims?
Thanks for the tip about securing the shelves to the wall; mine is actually already installed.
