ᐅ How can I stabilize IKEA HEMNES furniture on an uneven floor?
Created on: 24 Mar 2022 19:07
Giuseppina
Giuseppina
24 Mar 2022 19:07
I recently assembled some IKEA Hemnes furniture, mainly dressers and shelves. Unfortunately, my floor is not completely level – it has slight unevenness that causes some furniture pieces to wobble or lean slightly. I want to avoid any damage to the furniture or unsafe situations, especially since I have children at home.
So my question is: What methods or materials would you recommend to effectively stabilize IKEA Hemnes furniture on uneven floors? Are there any tips for securing these pieces firmly and safely without affecting their appearance or requiring too much effort?
I look forward to your experiences and advice!
Keatondra
24 Mar 2022 19:25
Hello Giuseppina,
First of all, it’s great that you’ve identified the issue with the uneven floor, as furniture like the HEMNES, which is often relatively tall and narrow, can become wobbly quickly and that can be uncomfortable or even dangerous.
My recommendation comes in several steps:
- Start by checking the exact uneven areas with a spirit level so you know precisely where you need to compensate.
- Use furniture wedges or small adjustable plastic feet – these can be placed under the furniture to reduce the risk of tipping.
- Another option is to attach small felt pads or cushioning pads to the furniture legs, which not only protect the floor but also help balance out minor unevenness.
- For bigger issues, special furniture floor levelers from a hardware store can be glued or screwed under each leg.
For permanent stabilization, if possible, secure the furniture with the wall brackets provided. This is especially important for HEMNES units, as they can be quite top-heavy.
I hope this helps!
Thierryzar
24 Mar 2022 20:02
To stabilize IKEA HEMNES furniture on uneven floors, I recommend:
- Using furniture shims or adjustable furniture feet
- Always securing furniture to the wall
- Applying leveling compound or adjustable pads if necessary
These are the most effective measures.
pikin
26 Mar 2022 08:14
Regarding the stabilization of IKEA HEMNES furniture on uneven floors, there are several relevant points to consider:
- Floor irregularities should be carefully measured before assembling the furniture, ideally using a spirit level or digital inclinometers.
- Furniture wedges made of wood or plastic are a proven solution. Make sure they are stable and non-slip to avoid creating additional hazards.
- Plastic or rubber pads under the furniture legs can help compensate for minor unevenness and increase stability.
- For long-term stability, attaching the furniture to the wall is recommended, which IKEA also explicitly requires for HEMNES. This usually involves the supplied safety brackets, including anchors and screws.
- If the floor is severely uneven, using a floor leveling compound in the critical areas may be advisable to create a flat surface.
Attention should also be paid to the visual aspects and the use of gentle materials for the flooring to prevent damage.
Combined, these measures significantly improve the furniture’s stability.
Giuseppina
26 Mar 2022 18:46
Keatondra schrieb:
Use furniture shims or small adjustable plastic feet – you can place these under the furniture to reduce the risk of tipping.
This option sounds very interesting, especially the adjustable feet. Does anyone know if they are easy to install and if they are suitable for wooden furniture like HEMNES?
pikin schrieb:
Plastic or rubber pads under the legs of furniture can help compensate for minor unevenness and increase stability.
Are rubber pads also recommended for parquet flooring, or could they leave stains? I would prefer not to risk any visible damage to the floor.
I’m also interested in recommendations for wall mounting when the floor is uneven. Are there special wall mounts that offer some flexibility?
Keatondra
27 Mar 2022 09:53
Yes, I can confirm that. Adjustable furniture glides or screw-on feet are usually very easy to attach to the furniture leg with a screw. IKEA HEMNES furniture is generally made of solid wood or wood composite, which allows for a secure installation. When purchasing, make sure that the screws and threaded parts are compatible.
Giuseppina schrieb:
Are rubber pads also useful on parquet floors, or can they leave stains?
Rubber pads can sometimes cause discoloration on certain parquet floors, especially if exposed to moisture over time or if made from low-quality material. High-quality felt or cork pads are better suited as protective bases and also provide slight height adjustment.
Giuseppina schrieb:
Also, I would be interested to know if there are recommendations for wall mounting when the floor is uneven. Are there special wall mounts that are more flexible?
Wall mounting remains the most stable solution for uneven floors. You can use longer wall plugs or special spacers to compensate for small gaps between the furniture and the wall. It is important to securely fix the furniture to prevent tipping over.
