ᐅ How can I securely mount IKEA Metod wall cabinets to drywall?
Created on: 11 Oct 2022 08:23
tomomau
tomomau
11 Oct 2022 08:23
I am planning to install several IKEA Metod wall cabinets in my kitchen on a drywall surface. Since these cabinets will be quite heavy, I want to make sure the installation is stable and secure over the long term. My question is: How can I safely mount IKEA Metod wall cabinets on a wall made only of drywall?
Which fasteners and technical details should I consider? Are there specific anchors or wall plugs that are particularly suitable? Is it better to reinforce the wall internally or to use mounting frames?
I look forward to practical tips and experiences that will help ensure a secure and load-bearing installation without causing damage.
CHENFAR
11 Oct 2022 09:47
Basically, mounting heavy wall cabinets on drywall without a direct supporting structure is problematic. Drywall alone is not strong enough to securely hold the weight.
Recommendations for secure installation:
- First, locate the wood or metal studs behind the drywall using a suitable stud finder and attach the cabinets directly to these studs.
- Use high-quality heavy-duty anchors or multi-purpose wall plugs if direct stud mounting is not possible.
- Alternatively, a reinforced mounting panel (e.g., an OSB board) can be screwed onto the wall to serve as a support frame for the cabinets.
Without stud mounting, there is a high risk of the cabinets pulling out and causing long-term damage.
Fitigu
11 Oct 2022 10:19
In addition to CHENFAR’s points:
- IKEA Metod cabinets are usually mounted on a frame that is screwed to the wall. For drywall, it is strongly recommended to fix the frame into the studs.
- Most drywall anchors (e.g., hollow wall anchors) are designed for light loads only, so multi-purpose or toggle anchors, despite having higher load ratings, are only partially suitable.
- If no studs are accessible, an additional solid wood board should be installed behind the drywall before mounting, secured at least to the studs.
These measures increase safety and reduce the risk of damage.
mabla
11 Oct 2022 12:03
Gypsum board alone does not provide stable support for Metod wall cabinets.
Always mount directly into the wall studs, or otherwise use a suitable backing board.
Cavity anchors are only suitable for lightweight items.
Tinaneo
12 Oct 2022 07:54
CHENFAR schrieb:
Without stud anchoring, there is otherwise a high risk of breakouts and long-term damage.
I completely agree. However, there are also specialized anchors for drywall that can handle significantly higher loads – such as metal dynamic toggle bolts. Nevertheless, in my opinion, their safety and durability for supporting hanging cabinets should be critically evaluated.
Furthermore, I wonder if all users really know how to reliably locate the studs. A simple electronic stud finder is often not sufficient, especially with metal studs. Incorrect placement of anchors can quickly lead to problems.
Therefore, if in doubt, I recommend providing additional reinforcement behind the drywall or even using mounting frames or metal profiles that can be attached to the wall.
TEOZAR
12 Oct 2022 14:12
I would like to summarize systematically what needs to be considered for the secure installation of IKEA Metod wall cabinets on drywall:
- Metod cabinets come with a mounting frame that is attached to the wall.
- The primary load should always be supported by the wall studs, as drywall panels alone do not have high load-bearing capacity.
- Locating studs: The best results are achieved using electronic stud finders or by lightly tapping to identify hollow and solid areas.
- For the screws, a length of at least 6 cm (2.4 inches) is recommended, with suitable wood-thread or metal-thread screws depending on the type of stud.
- Alternative fastening: A crosswise installed, adequately sized wooden batten (e.g., 18 mm (0.7 inches) OSB or plywood) fixed to the studs provides additional security.
- Anchors intended only for drywall should only be used for very light elements, never for Metod wall cabinets.
Important: Following these steps ensures a permanently secure installation, prevents damage to the wall, and protects users from accidents.
