ᐅ What care instructions are recommended for IKEA Metod wooden cabinet fronts?
Created on: 30 Jan 2020 09:13
Neoson
I recently bought a kitchen with IKEA Metod wood fronts and am now looking for specific care instructions. I am especially interested in how to keep the surfaces clean and well-maintained over time without causing damage. Are there particular cleaning products that should be used or definitely avoided? How should moisture, heat, or mechanical stress be handled?
Thank you for concrete experiences and tips regarding the wood fronts, as I want to avoid discoloration or delamination of the surface over time.
jelite
30 Jan 2020 13:33
Hello Neoson,
I think your question about oils and waxes is valid. In general, the wooden fronts of IKEA Metod cabinets usually have a painted or sealed surface. This means they do not require separate treatment with oil or wax. In fact, applying such care products can sometimes be undesirable, as it may cause the surface to become sticky or darken.
Common mistakes:
- Using household bleach or alcohol – these can damage the sealant.
- Abrasive cleaners (such as detergents or scouring pads) can scratch the surface.
- Using too much water on the fronts, which can cause the wood to swell.
I recommend reading IKEA’s product description carefully; the care instructions are usually well explained there.
GALEO4
30 Jan 2020 14:27
Hmm, I find the care instructions often a bit too cautious. Of course, overly aggressive products or improper handling can cause damage, but wood fronts are basically quite durable.
At home, I simply use regular household cloths with a mild dish soap and that works well for me. The overly cautious application of special oils or waxes seems more like a marketing strategy.
Naturally, if someone constantly uses harsh cleaners, scratches will appear – but that should be obvious.
Neoson
30 Jan 2020 15:04
It’s interesting that there are different experiences with this. When it comes to maintenance, I would prefer to play it safe, especially since the surface and appearance are important to me.
Maybe a follow-up question: How should corners and edges be handled? I have noticed on some wooden fronts that small damages can appear quickly there. Is there any special care or precautions for these areas?
LOJOPAR
31 Jan 2020 08:43
Regarding corners and edges on wooden fronts, I recommend the following:
- Avoid any impacts or bumps in these areas, as edges tend to be more vulnerable than flat surfaces.
- When cleaning, handle these spots with extra care to prevent wearing off the sealant.
- For minor damage, gently sand the area with fine-grit sandpaper and then carefully apply matching wood varnish to prevent the damage from spreading.
In summary: edge care mainly involves careful handling and gentle cleaning.
If you have real wood fronts, occasional oiling during winter can be beneficial, but this is generally not necessary for IKEA Metod fronts since they are sealed.
Juan31
31 Jan 2020 09:10
Neoson schrieb:
How do you handle corners and edges? I've noticed that small damages can appear quickly on some wooden fronts.
Edges are often the critical point because the thinner sealant there is most vulnerable. Therefore:
- Avoid heavy cleaning on edges
- Keep contact with water to a minimum
- Wipe dry immediately if moisture occurs
This ensures that no moisture penetrates and helps prevent damage.
Forrest
31 Jan 2020 09:24
I completely agree with Juan31, and I have to say: for me, the tried-and-true gentle touch always helped.
Wooden surfaces definitely attract fans of aesthetics, and they reward you with years of loyalty. 😄
Just don’t overdo it with the surfaces – and yes, when cleaning, it’s better to be gentle rather than harsh.
To keep them looking good for a long time, it’s also a good idea to use a slightly damp microfiber cloth right after cooking, so that steam and other residues don’t leave marks.
