ᐅ How can I securely mount Ikea Metod wall cabinets on drywall (plasterboard) walls?
Created on: 8 Jun 2021 09:12
Brent54
Hello everyone, I am planning to mount my Ikea Metod wall cabinets on drywall soon, but I have some concerns about load capacity and the correct mounting method. The drywall panels are 12.5 mm (1/2 inch) thick and installed on a wooden stud wall. My main question is: which wall plugs and screws are recommended for this combination, and how can I ensure the cabinets are securely and permanently fixed without damaging the wall? Are there any special tips or installation tricks to keep in mind with drywall, especially for relatively heavy kitchen cabinets like Metod? Thanks in advance for your experiences!
Thanks for the tips so far; they have been really helpful. One more question: What size should the holes be for the toggle bolts? I’ve read that incorrectly drilled holes are often the reason for poor holding strength. Also, can I hang the cabinets directly without a mounting rail, or is using a mounting rail recommended for stability with drywall? If so, what is the best thickness and the recommended fastening methods for the rail?
For toggle bolts, you need to match the hole size precisely to the bolt length, which is usually indicated on the packaging. A hole that is too large will result in poor holding strength, while a hole that is too small will prevent insertion.
Regarding the mounting batten: strongly recommended! A sturdy wood or MDF batten (at least 18mm (0.7 inches) thick) ensures even load distribution and makes secure installation much easier. You can screw the batten into the timber studs using long screws, then hang the cabinets on it. This significantly reduces the load on the drywall panels.
Brent54 schrieb:
Can I hang the cabinets directly without a mounting strip, or is the mounting strip recommended for stability on drywall?I would almost always recommend using the mounting strip, especially on drywall! 😊 It acts as a backup for your wall and makes the whole process much less stressful. Sure, you can technically screw directly into the drywall, but the strip takes a lot of the pressure off and distributes the load like a pro. Have fun with the installation!
It’s interesting how many people here simply attach directly to the studs. But honestly: is that always sufficient? I’m also skeptical about the mounting batten because it shifts the weight and support point – this could lead to unexpected moments that aren’t considered. Toggle bolts are more of a last resort, and with drywall alone, you will always struggle with heavier loads without additional reinforcement. My provocative theory: if you strengthen the wall (with plywood panels or similar), you don’t need a mounting batten, but most people don’t bother with that. What do you think?
Oh, I see that quite differently! For me, the mounting strip is the gamechanger! It provides a solid feeling and makes installation super easy! 💪 The extra stability is priceless, especially if you have children or a lot of activity in the kitchen. I hung my Metod cabinet wall on drywall using a mounting strip a year ago, and it’s holding up great, no problems! So: don’t be afraid to use the strip and go for it! You got this!
Gilbert schrieb:
If you reinforce the wall (with plywood panels or similar), you don’t need a mounting batten, but most people don’t go that route. That resonates with me. I considered installing an OSB board behind the drywall, but with my finished construction, that would require significant effort. Therefore, I believe that using a mounting batten is a practical solution, which I should not underestimate from a structural standpoint either.
My next steps will be:
- Locating the studs using a digital stud finder
- Cutting a suitable mounting batten from wood at least 18mm (0.7 inches) thick
- Securing the batten with long chipboard screws directly to the studs
- Using toggle bolts for additional support in the gaps
Thanks to everyone for the valuable tips; this really helps me move forward!
