ᐅ How can I securely attach IKEA PLATSA furniture to drywall partitions?
Created on: 7 Dec 2024 08:43
JeremiahjaJ
Jeremiahja7 Dec 2024 08:43Hello everyone,
I am currently facing the challenge of securely and permanently mounting several IKEA Platsa units to a drywall-only wall. Since the Platsa series can be quite large and heavy, I want to make sure everything is installed as solidly as possible.
My questions are as follows:
- Which fastening methods are best suited specifically for drywall (without additional steel or wooden substructures)?
- What type of anchors or screw combinations are recommended to reliably support the weight?
- Are there any tips or tricks for distributing the load to reduce the risk of the furniture pulling away or damaging the wall over time?
- Is it always necessary to attach to the existing metal studs in the drywall, and how can these be best located?
I would greatly appreciate detailed experiences and recommendations, as I want to ensure a long-term secure installation without worrying about accidents or damage.
Thanks in advance for your advice and suggestions!
Hello Jeremiahja,
your concern is absolutely justified, as securely mounting heavy furniture on drywall requires a bit more planning than on solid walls. I would like to provide you with a clear guide on how to proceed when attaching IKEA PLATSA to such walls:
- Load distribution and studs: Drywall consists of gypsum boards mounted on metal or wooden studs. The highest load-bearing capacity is provided by fastening directly into these studs. The first step is therefore to accurately locate the stud profiles using a digital metal or cable detector.
- Mounting hardware: Ideally, you should screw the mounting plates or furniture directly into the studs using standard wood or sheet metal screws. If you cannot fasten into the studs, use high-quality specialized drywall anchors—such as metal toggle bolts or metal hollow wall anchors—designed specifically for heavy loads.
- Pre-drilling and installation: The drill bits and screws must match the anchor size and wall thickness. Before installation, always check the load capacity of individual fastening points. Considering the weight of the PLATSA furniture, use multiple fastening points to distribute the load evenly.
- Additional reinforcement: If possible, you can install wooden battens or an additional backing board behind the drywall, which then distributes the load over a larger area.
Summary:
1. Use studs as the primary load-bearing base whenever possible.
2. When fastening into gypsum board, use high-quality metal hollow wall anchors.
3. Distribute the load across several points.
4. Add reinforcements if necessary.
If you like, I can also provide tips on suitable tools and specific anchor models. Good luck with your installation!
Summary:
Nabla64 schrieb:
The greatest load-bearing capacity is achieved by fastening into these studs. The first step is therefore to precisely locate the stud profiles using a digital metal or cable detector. This is a crucial point – without precise stud location, safety is significantly compromised. I would like to add how I installed PLATSA units on drywall partitions and which technical details you should consider:
1. Stud detection and analysis: A metal or stud finder with depth detection is ideal. It’s not only about finding metal studs but also avoiding electrical cables and plumbing pipes. I recommend verifying the detection with two different devices or by measuring multiple times.
2. Weight of the furniture: PLATSA units can be quite heavy depending on size and configuration. For example, I mounted cabinets about 80 cm (31.5 inches) high weighing approximately 25–30 kg (55–66 lbs) per module. A simple drywall screw is not sufficient for such loads.
3. Use mounting boards: To increase the load distribution area, I screwed an 18 mm (0.7 inch) plywood panel directly to the studs. The furniture was then attached to this panel, which provides significantly more stability and reduces local stress.
4. Choice of anchors: When a stud is not available, I only use metal toggle anchors, which can support loads up to 50 kg (110 lbs) per fixation point if properly installed.
5. Drill depth and screw length: Make sure to drill to the correct depth, otherwise the anchor won’t hold properly. Screws should be long enough to engage at least 25 mm (1 inch) into the stud or the hollow-wall anchor’s counterpart.
6. Multiple fixation points: For larger furniture, always use several points at the bottom, top, and sides to prevent tipping and leverage forces.
Question: Do you already know the dimensions and approximate weight of the PLATSA units you want to install? That would allow for the most detailed recommendation.
Jeremiahja7 Dec 2024 18:59Domau0 schrieb:
Question: Do you already have the dimensions and approximate weight of the PLATSA units you plan to install? That would allow for the most precise recommendation. Thank you for the detailed response! The dimensions vary somewhat; I’m planning with two units approximately 80x60x35 cm (31.5x24x14 inches) and one larger unit about 120x60x35 cm (47x24x14 inches). According to the specifications, the heavier ones weigh between 25 and 40 kg (55 to 88 lbs) fully loaded. The wall consists of metal studs; I used a metal detector to roughly locate them but still need to verify more precisely.
I think an additional mounting plate, as you suggested, makes sense—especially since the load varies. Is there a specific type of wood that would be better suited, or is standard plywood sufficient?
It’s also important for me to have a fastening strategy that won’t damage the drywall over time (no cracks, no sagging furniture).
What should I pay attention to in detail when selecting screws and wall plugs? Are there preferred types that allow me to reliably estimate the load capacity?
I also have a quick question about load distribution: Should I secure each piece of furniture individually to the wall, or can I install a continuous rail or strip attached to the wall that supports multiple units?
Thanks again!
Jeremiahja schrieb:
An important consideration for me is a fastening strategy that does not risk damaging the drywall over time (no cracks, no sagging furniture). Very good point! The risk of cracks or even the anchors pulling out almost always comes from uneven or excessive loads on too small areas. A mounting plate made of plywood is ideal here – it provides a significantly larger surface area and distributes the weight across several studs.
Plywood boards with a thickness of 18 mm (0.7 inches), preferably birch or beech, are sturdy and hardly warp. Avoid using soft woods or particleboard, as this can lead to uneven loading later on.
For anchors, metal toggle anchors in the drywall are recommended if you don’t hit a stud exactly. For screws, galvanized or stainless steel screws with fine threads are advised to ensure a firm hold.
Regarding load distribution: a continuous mounting rail that connects multiple pieces of furniture is a very good idea. This further distributes the load, and the furniture acts as a single unit, significantly reducing the risk of tipping and leverage forces.
Tip: The rail itself should be fixed to at least three points on the studs, ideally using carriage bolts and sufficiently long anchors to guarantee a secure, long-lasting hold.
Best regards and good luck!
