ᐅ How can I securely fasten IKEA Metod kitchen cabinets to different types of walls?
Created on: 16 Dec 2024 08:17
paamadeus
I have a question about securely mounting IKEA Metod kitchen cabinets, specifically how to firmly attach them to different wall types. My wall consists partly of conventional masonry (brick) and partly of a lightweight drywall with a stud frame behind it. My concern is that the cabinets, especially the wall cabinets, hold securely and do not wobble or come loose during everyday use.
What are the best methods and materials to reliably fasten the Metod cabinets – both to solid masonry and to lighter drywall partitions? Are there special anchors or fastening systems that work particularly well? Should additional reinforcements be installed behind the drywall? I appreciate any experience, tips, and also warnings about common mistakes, as I want to approach the installation in a truly professional manner.
paamadeus
16 Dec 2024 14:08
Filippo schrieb:
Would you like more details about the tools used or screw sizes? Also whether the walls have any other special features?
Thanks, definitely! My masonry wall is 24cm (9.5 inches) brick, with no insulation inside. For the drywall partition, I only have a rough plan so far – I know that the studs are made of metal profiles, not wood. So I’ll need to check more precisely how frequently the studs are spaced and which marking tools or cable reels might be useful.
Later on, I would like to know exactly which screw dimensions (length, diameter) are suitable for the different materials. Also whether I need special drill bits for drilling.
Furthermore: How can I prevent screws from slipping or the drywall board from cracking? Are toggle bolts or molly bolts really the best option? Or are there alternatives?
blapau
16 Dec 2024 15:47
paamadeus schrieb:
How can I prevent screws from slipping or the drywall breaking in gypsum board walls? Are toggle bolts or wing anchors really the best option? Or are there alternatives?
Cavity anchors such as toggle bolts or wing anchors are indeed the preferred choice in drywall constructions because they distribute the load behind the board, protecting the material. Alternatives like specialized drywall anchors (e.g., metal wing anchors or spacer anchors) can also be used and sometimes offer even higher load capacity.
For drilling: A masonry or multi-purpose drill bit with the exact diameter for the anchor is ideal; when drilling into metal studs, use metal drill bits.
Screws: It’s best to use screws with a 6mm (1/4 inch) diameter, long enough to fully engage the anchor and reach into the stud—usually 50–80mm (2–3 inches) in length.
Tip: Before fastening, check the wall with a stud finder and align the anchor holes precisely to ensure the screws are driven directly into the studs.
lisku
16 Dec 2024 16:20
Metod cabinets are mounted on metal hanging rails. For masonry walls, universal anchors are used; for drywall, they are secured only to studs with metal toggle anchors. Everything has held up without any issues.
DUVIN
17 Dec 2024 08:04
Method for drywall construction with metal studs: toggle bolts and screws into the stud, not just the drywall panel. For masonry, use hammer-in anchors; otherwise, use a battens between the drywall panels for better load distribution.
koduga
17 Dec 2024 09:58
Filippo schrieb:
2. Drywall (plasterboard):
- Important: Check where the studs (wood or metal profiles) are located – using a stud finder.
In addition to the tool: Don’t get discouraged if it seems complicated at first. Sometimes you can also locate the studs by gently tapping on the wall. I found it difficult the first time, but with some patience everything eventually fit securely in place. Long-lasting security provides peace of mind.
