ᐅ What steps are necessary to securely mount IKEA Metod wall cabinets?
Created on: 5 Oct 2016 14:03
Melinael
Hello everyone, I would like to ask for a clear and well-structured overview: What specific steps are necessary to securely mount IKEA Metod wall cabinets? I am particularly interested in how to account for different wall types (e.g., concrete, drywall / plasterboard, timber framing), which fasteners are suitable, and which mistakes should definitely be avoided—especially regarding load capacity and long-term safety. Who among you has experience or tips on the best, most stable, and professional way to do this?
RUBEN54
6 Oct 2016 12:05
Melinael schrieb:
how to calculate load capacity
To estimate the load capacity, it helps to calculate the total weight of the cabinet plus its maximum load. This is done by adding:
- Weight of the empty cabinet (use approximate manufacturer specifications)
- Plus the estimated weight of the stored items
Then, divide the total load by the number of mounting points. It is also important to include a safety margin, planning for at least 20–30% more load capacity. For anchors and wall plugs, always refer to the manufacturer's load ratings.
lechen
6 Oct 2016 12:18
Make sure the wall anchors are suitable for the type of wall. Drywall requires different anchors than concrete. Drill holes to the correct depth, fully insert the anchors, and avoid overtightening the screws.
silako
6 Oct 2016 14:24
RUBEN54 schrieb:
Estimating the total weight of the cabinet plus maximum load
That is clear, but what I would add is a check to verify whether the wall is actually as load-bearing as specified – this could include a load test or core drilling sample, if possible. One should not rely solely on given information, especially with older buildings.
Kukar
7 Oct 2016 09:36
Just a brief note: Properly tightening the screws is important. Not too tight, or the board will crack; not too loose, or the cabinet won’t be securely mounted.
Lidan56
7 Oct 2016 10:04
Always use the original fasteners from IKEA. They are generally tested for the Metod series and provide reliable safety.
Melinael
7 Oct 2016 18:44
Thank you for the many helpful contributions! To summarize, here are the key steps I understood for securely mounting the IKEA Metod wall cabinets:
- Accurately identify the wall type (CONCRETE, BRICK, DRYWALL)
- Choose appropriate anchors and screws based on the wall type (e.g., heavy-duty anchors, cavity anchors)
- Realistically calculate the cabinet weight including contents and distribute it across the fixing points
- Measure and mark precisely (using a spirit level)
- Observe the correct drill hole depth and carefully screw in the screws
- For drywall, consider reinforcement behind the panel if necessary
- Use original IKEA mounting materials whenever possible
If anyone wants to add further important points, that would be great!
