ᐅ How can I securely attach IKEA Metod kitchen cabinets to brick walls?
Created on: 8 May 2024 09:17
V
Vinnar63
V
Vinnar63
8 May 2024 09:17
Hello everyone, I am currently planning to install my IKEA Metod kitchen cabinets on a brick wall and am looking for a secure and long-lasting fastening solution. The wall is made of red bricks, quite old and somewhat uneven. Due to the size and weight of the cabinets, a stable attachment is extremely important to me. I have already considered chemical anchors, metal anchors, and wood screws but am uncertain which option is truly the best to ensure load-bearing capacity while minimizing damage to the wall. Which fastening methods and tools would you specifically recommend to securely mount IKEA Metod kitchen cabinets to a brick wall without compromising stability or causing damage? I am especially interested in tips on wall preparation, suitable types of anchors, screw lengths, and any tricks for the installation. I look forward to your experiences and advice.
Elijah42
8 May 2024 09:45
You should use heavy-duty anchors, preferably metal expansion anchors, as they hold very well in brick. Pre-drill with an appropriate masonry drill bit to prevent cracking. Choose screws according to the anchor size, usually 6–8 cm (2.5–3 inches) long.
Joe52
8 May 2024 11:28
I completely understand your concern. I once installed kitchen cabinets on an old brick wall myself and was quite uncertain at first. What worked well for me was thoroughly cleaning the wall before installation and removing any loose material to ensure the anchors hold securely. If you have the opportunity, take some time to align the cabinets properly, as this makes a huge difference later when loading them. I was initially worried about cracks, but with chemical anchors, everything feels very stable.
CHENFAR
9 May 2024 07:55
For mounting IKEA Metod kitchen cabinets on brick walls, I strongly recommend the following procedure:
- First, inspect the wall surface for loose mortar residues and remove them to maximize support.
- Drill holes using a hammer drill and a masonry bit (Ø 8 mm (0.3 inches)).
- Use metal expansion anchors or chemical anchors designed specifically for porous materials. Chemical anchors provide better load transfer but are more complex to install.
- Screws should engage at least 6 cm (2.4 inches) into the anchor; for heavy kitchen units, prefer screws with an 8 cm (3.1 inches) length.
- Load distribution can be improved by adding extra fixing points, especially for large cabinets.
I advise against using simple plastic anchors, as they usually do not hold reliably in old brick.
In general: The more suitable the anchor is for the masonry, the more secure the fixation will be.
V
Vinnar63
9 May 2024 10:03
CHENFAR schrieb:
Use of metal expansion anchors or chemical anchors specifically designed for porous building materials.
Thank you for the clear assessment. I am particularly interested in whether the additional effort required for chemical anchors is justified by their higher load capacity, or if metal expansion anchors are sufficient for a standard, solid brick wall. Are there any risks associated with using chemical anchors in older walls (e.g., damage to the bricks caused by resin injection)? What has been your experience? Also, when drilling with a hammer drill in older bricks, is there anything special I should keep in mind to prevent the bricks from spalling or cracking?
