ᐅ How do I replace Malm bed slats?
Created on: 1 Mar 2022 09:17
Fogoso
Fogoso
1 Mar 2022 09:17
Hello everyone, I plan to replace the slats in my IKEA Malm bed because some of them are quite worn out and partially broken. However, I’m unsure about the best way to proceed since the slatted frame is fixed in place, and I want to avoid mistakes that could affect stability or comfort.
Specifically, I’m interested in:
- How can I gently remove the old slats without damaging the frame?
- Are there particular dimensions or materials I should consider for the new slats?
- Do I need to pay attention to a specific fastening method?
- And which mistakes should I definitely avoid?
I look forward to your experiences or tips. Thanks in advance!
PRA64
1 Mar 2022 11:42
Hello Fogoso,
I have replaced slats a few times on a Malm bed and here is a brief step-by-step guide for you:
1. Preparation: Remove the mattress and any bedding completely from the bed. This gives you full access to the slatted frame.
2. Removing the slats: On Malm beds, the slats are often mounted on plastic clips. Gently pull the slats upwards out of the holders. Be careful not to use too much force to avoid breaking the wooden frame or the clips.
3. Selecting new slats: Make sure the replacement slats have the same length, width, and thickness. It’s easier if you take the old slats with you to get the exact measurements. High-quality beech wood is popular because it is stable and flexible.
4. Installing the new slats: Carefully insert them back into the clips. They should sit firmly and evenly but not at an angle.
5. Check: Once all slats are in place, test to make sure nothing is loose. The stability of the bed frame must not be affected.
Common mistakes I have seen:
- Installing slats too loosely or too tightly, which reduces durability.
- Using incorrect measurements, compromising comfort and causing damage.
- Applying too much force when removing slats, leading to damage.
If you keep these points in mind, the replacement should go smoothly. 🙂
If you have any more questions, I’m happy to help.
Siflo
2 Mar 2022 14:08
That is absolutely correct. Additionally, I recommend carefully checking the condition of the support points (plastic clips or rubber pads). After extended use, these often become brittle or may be missing and should be replaced if necessary to prevent noise and vibrations.
PRA64 schrieb:
Remove slats: On Malm beds, the slats are often attached to plastic clips.
To remove the slats, I suggest carefully inspecting the brackets or frame in case screws are additionally securing the slatted frame. For models with the slatted frame firmly screwed in, it may be necessary to loosen these screws before the slats can be removed.
In summary: before removing anything, document the exact position of each slat (for example, with a photo) so everything fits correctly during reassembly. Also, pay attention to the spacing between the slats, as too wide a gap can reduce mattress performance.
Best regards!
PRA64
3 Mar 2022 08:51
Siflo schrieb:
Additionally, I recommend thoroughly checking the condition of the support points (plastic clips or rubber pads).
Very good point! This is often overlooked. If the rubber or plastic holders are porous or damaged, it can quickly cause rattling, or the slats may break more easily.
Siflo schrieb:
For models with fixed screw-mounted slatted frames, it may be necessary to loosen these screws.
This actually happens quite often, especially with older Malm beds or models equipped with additional stabilizers.
I would also recommend choosing replacement slats with some flexibility: boards that are too rigid significantly reduce comfort when lying down.
If you’re not confident with DIY skills, it’s better to take your time to measure everything precisely and, if in doubt, get a recommendation from the IKEA service—this way, you can avoid any surprises in the end.
Good luck, and feel free to share how it went! 🙂
