ᐅ How do I repair Ikea Hemnes furniture when the fittings are damaged?
Created on: 24 Sep 2022 10:17
NONLUCIEN
Hello everyone, I need some help with a topic that I’m sure some of you are familiar with: How do you repair Ikea Hemnes furniture when the fittings are damaged?
Specifically, I’m talking about the typical metal fittings used to connect the wooden parts – such as dowels, cam locks, hinges, and other fasteners. On my Hemnes dressers and shelves, these often come loose, fit loosely, or are even broken in some cases. This causes the furniture to wobble or lose stability.
I’ve been wondering whether it’s best to simply replace the original fittings or if it’s better to use third-party replacements. I’m also curious about how to repair damaged drill holes or wooden areas so that new screws will hold properly.
Does anyone have practical experience with the best way to approach this? Are there common beginner mistakes that should definitely be avoided? I’d appreciate detailed advice and explanations!
Nathanaelk
25 Sep 2022 10:58
NONLUCIEN schrieb:
Did I understand correctly that the holes should be filled with wooden dowels or wood filler and then re-drilled after drying?
Exactly, this is the most common and sustainable method.
Step-by-step procedure:
- Remove screws and cam connectors
- Thoroughly clean out any worn holes and remove dust
- Lightly coat suitable wooden dowels with wood glue
- Tap the dowels into the holes and carefully remove any protruding wood
- After complete drying (at least 24 hours), re-drill at the same spot (make sure to match the drill bit size to the screws)
This ensures a secure anchoring for the cam connector.
Regarding spare parts:
- Original cam connectors from Ikea are precisely manufactured and guarantee perfect fit.
- Commercial spare parts from hardware stores may work but often have slight differences in size or thread diameter.
- If repairs are needed frequently, buying from Ikea is usually better to avoid repeated dismantling.
One more tip: if you have loose hinges, also check if the side panel is still intact and, if necessary, use appropriate wood fillers before re-screwing.
Trate47
25 Sep 2022 12:09
Nathanaelk schrieb:
Original cam connectors from Ikea are precisely manufactured and ensure a perfect fit.
That’s exactly right! 👍
One more thing: If the originals are ever out of stock, you can often use inexpensive replacements from a hardware store – but those usually don’t fit quite as snugly and don’t feel as high quality, so you can notice the difference.
For loose drill holes, as mentioned before, you can mix wood glue with finely ground sawdust. This creates a good paste that fits perfectly into the holes and, once dry, is often even stronger than commercial wood filler.
A little patience while drying always pays off – otherwise, it all gets mushy. And always tighten screws gently, especially in pine or veneered parts, since there is a high risk of stripping or breaking out the material.
Lamar
26 Sep 2022 16:22
Trate47 schrieb:
Always tighten screws gently, especially with pine or veneered parts, as there is a high risk of tearing out.
Honestly, the whole IKEA thing is really a mix of clever mass production and... well, average durability. It’s no surprise that the fittings eventually give way.
I would rather recommend not just repairing the Hemnes components but reinforcing them with stronger fasteners, such as additional metal brackets or small corner braces. That might not be original, but it makes the furniture more durable.
Sometimes “repairing” doesn’t make much sense if the base no longer holds. Better to do some tinkering and reinforcement than constantly having to tighten screws afterward.
