ᐅ How do I repair damaged screw holes in Ikea Hemnes furniture?
Created on: 12 Dec 2020 08:37
IXLOPLO
IXLOPLO
12 Dec 2020 08:37
Hello everyone, I have a problem with some screw holes in my Ikea Hemnes furniture being significantly damaged. This shows up as screws no longer gripping properly, sitting too loosely in some cases, or spinning when tightened. The furniture parts are mostly made of MDF and engineered wood, which unfortunately become porous quickly if screws are overtightened.
My question is: What is the most effective and durable way to repair damaged screw holes in Ikea Hemnes furniture without having to replace entire parts? Are there proven methods for both the standard screw holes and the dowel holes? I would appreciate tips that can also be applied by non-professionals. Information on materials, tools, and procedures that keep the furniture stable and functional would be especially helpful.
besau
12 Dec 2020 09:12
For damaged screw holes in wood-based materials such as MDF, I recommend using simple wood filler. Fill the damaged hole with it, allow it to dry thoroughly, sand it smooth, and then drill a new hole for the screw. Alternatively, wooden dowels or sticks glued into the hole with wood glue can also help restore stability.
Liduta
12 Dec 2020 12:45
Hello IXLOPLO and everyone interested, I’m happy to provide a brief guide on how to repair damaged screw holes in Hemnes furniture.
- First, carefully clean the old hole, removing any loose material if necessary.
- Then you can fill the damage with wood glue and wood dust or use special wood filler. Wood dust usually comes from the same material, for example, by collecting MDF dust.
- It is important to allow the filler to fully cure, which typically takes 24 hours.
- After that, either carefully re-drill the repaired hole or reinforce it with a suitable wooden or plastic dowel.
- For dowel holes, I strongly recommend using new dowels during the repair, as the stress on these points is higher.
Common mistakes include screwing in too soon while the glue is still wet; re-drilling the hole too large or too small; or using unsuitable materials, which reduces stability.
In summary: fill, let cure, carefully re-drill or insert dowel. This way, your Hemnes furniture remains stable and suitable for everyday use.
keelko
13 Dec 2020 07:53
Liduta schrieb:
Fill, harden, re-drill if needed, or insert a suitable anchor. This way, the Hemnes stays stable and durable for everyday use.
Exactly! I did the same myself – and it was actually quite enjoyable when done the right way. One tip: it’s not just about the glue; the screws themselves matter too. If you use screws with a slightly larger diameter, they hold even better, especially after the repair. And if you do it properly, no one will notice there was ever an issue. Good luck with your project!
