ᐅ How can I repair damaged corners on Ikea PLATSA units?
Created on: 2 Nov 2024 08:42
Karmu
Good morning everyone, I have an issue with my Ikea Platsa furniture, specifically with the damaged corners. I’ve noticed that, especially with these modular cabinets, the outer edges often get chipped or damaged from frequent moving and bumping. Sometimes you can also see the veneer peeling off or the particleboard underneath starting to splinter. Since I really appreciate this furniture and don’t want to buy new pieces or spend too much money, I’m interested in how to best repair the damaged corners. Are there proven methods, techniques, or materials to restore the damaged surfaces so they’re stable and visually appealing again? I’m specifically looking for advice on how to handle the corners of the wood panels—that is, the visible edges rather than the interior parts of the furniture. It’s also important for me to know whether these repairs can be done with common household items or if special tools or products are needed. Who has experience with this and can provide practical tips on how to proceed? Thanks in advance!
Jensson
3 Nov 2024 10:12
Sure, gladly: If there are larger corner damages that remain unstable with regular filler, I recommend the following approach:
- Cut a small piece of plywood or hardwood roughly the same size or slightly smaller than the damaged corner.
- Slightly chamfer the edges of this wooden piece to fit better into the corner.
- Apply wood glue both to the damaged corner area and to the wooden piece.
- Press the wooden piece firmly into the corner; this provides immediate stability.
- After drying, level any protrusions with sandpaper.
- Smooth the joint with wood filler to create a continuous surface.
- Then paint or veneer as previously described.
Important: Make sure the wooden piece fits tightly to maintain stability. This method is better than just filling when there is significant material loss.
blapau
3 Nov 2024 12:28
Additionally, I would like to mention that self-adhesive edge protection profiles are often suitable for repairing edge damage. These come in many color and material options, including ones that match most Ikea melamine surfaces.
Application is usually straightforward: lightly roughen the surface, degrease, carefully align the edge, and press firmly. For improved durability, you can further protect the edges with a bit of clear varnish. This prevents new damage while providing a clean appearance.
However, if you prefer the repair to be as inconspicuous as possible, using filler and paint is still the best option.
warrenka57
4 Nov 2024 08:17
I just wanted to mention that I always see the topic of repairing Ikea furniture as an emotional process as well. Of course, a functional repair is important, but with my Platsa pieces, I’ve also noticed that small cosmetic flaws don’t bother me much if the furniture is otherwise practical.
I think sometimes our fear that something might look ugly or imperfect holds us back so much that we don’t even start repairing. In the end, a pragmatic rather than perfect approach can sometimes help.
Still, I understand wanting to keep the furniture in good condition, so thanks to everyone for the tips.
juMira46
4 Nov 2024 21:03
Hey, this is a great topic – thanks for your tips! I think furniture repairs are little DIY adventures that show how much personality we put into our living spaces. When I fix my PLATSA corners, I often add small paint touches at the end to brighten things up a bit – turning the flaw into a real eye-catcher.
And when you use edge protectors, I believe they can be a bit visible and stylish – a touch of retro flair never hurts, right? 😉 That way, the corner becomes a focal point and you also have something to talk about when friends come over.
