ᐅ How can I repair damaged corners on Ikea PLATSA units?
Created on: 2 Nov 2024 08:42
Karmu
Karmu
2 Nov 2024 08:42
Good morning everyone, I have an issue with my Ikea Platsa furniture, specifically with the damaged corners. I’ve noticed that, especially with these modular cabinets, the outer edges often get chipped or damaged from frequent moving and bumping. Sometimes you can also see the veneer peeling off or the particleboard underneath starting to splinter. Since I really appreciate this furniture and don’t want to buy new pieces or spend too much money, I’m interested in how to best repair the damaged corners. Are there proven methods, techniques, or materials to restore the damaged surfaces so they’re stable and visually appealing again? I’m specifically looking for advice on how to handle the corners of the wood panels—that is, the visible edges rather than the interior parts of the furniture. It’s also important for me to know whether these repairs can be done with common household items or if special tools or products are needed. Who has experience with this and can provide practical tips on how to proceed? Thanks in advance!
Paunon
2 Nov 2024 09:11
Hello, for damaged corners on PLATSA, I use wood filler to fill holes and chips. Then, sand it smooth and touch up with matching varnish or wood paint. This way, it looks neat again afterward.
Jensson
2 Nov 2024 10:05
To address this topic more thoroughly, here is a brief step-by-step guide for repairing damaged corners on Ikea PLATSA furniture:
- First, carefully clean the damaged area and gently remove any loose parts.
- Next, use a suitable wood filler (preferably water-based and sandable). Apply it in several layers to restore the corner’s stability.
- Once dry, sand the area with sandpaper (grit 120 to 220) until the surface is smooth and seamless.
- Then, apply a matching paint or wood stain that closely resembles the original finish or veneer. If you can’t find the exact color, a wood touch-up pen or marker is often helpful for corrections.
Be careful not to apply too much filler at once and allow each layer to dry properly. If you have an edge protector or edging strip, you can carefully fix it with construction adhesive, as long as it hasn’t already come loose.
One more tip: For larger corner damages, you can fit a small piece of wood with wood glue to add extra strength. If you want, I can explain this in more detail.
flo-Theres
2 Nov 2024 12:47
An important note: Since PLATSA is made of particleboard with a melamine finish, it is crucial to carefully treat the edges during repair to prevent moisture from penetrating the wood. If the particleboard is exposed, the material can swell when wet and sustain further damage.
A useful tip is to apply a thin layer of clear varnish after filling and sanding the repair, which provides good moisture protection. There are also special repair markers for melamine surfaces that you can use to hide small scratches or damaged finish areas.
likuken
2 Nov 2024 15:33
I sometimes wonder if it would be much more sustainable to proactively protect new corner edges instead of dealing with repairs later on. Why does everyone rely on repairing damaged furniture rather than using some type of edge protector—whether made of plastic or metal—as a preventive measure?
Jensson schrieb:
If you have an edge protector or edge strip, you can carefully fix it in place using assembly adhesive
Exactly, this is where the idea takes root. A well-thought-out edge protection profile could save a lot of effort and preserve the appearance – a repair job on furniture often looks improvised and diminishes the aesthetics. Of course, not everyone wants to invest upfront, but in the long run, a protective measure is more worthwhile than patchwork.
Karmu
3 Nov 2024 07:54
Thanks in advance for the initial helpful tips. I also find the point about moisture resistance very important since the furniture will be in a kitchen with moderate humidity. Regarding gaps: I find your idea of using edge protectors interesting – does anyone have specific experience with these protective strips for PLATSA and how best to attach them? Are they visible or are there more discreet options?
Also, Jensson, could you please describe in more detail the method of using a small piece of wood as a filler for larger corners? For my corner, it looks like just filling it with putty won’t be enough anymore since the corner is basically broken off.
